E30 Suspension Refresh Question
  • Coldpasta
    • Oct 2022
    • 4
    I’m going to be refreshing the suspension of my late model e30 325i and am wondering what all parts y’all recommend? I have a list already and am wondering what else could possibly be needed.
    Billstein b8 shocks
    IEM sIII springs with front and rear spring insulators/bushing
    Front and rear shock mounts
    Front and rear adjustable sway bar links
    Control arms with lollipops
    80a Durometer control arm, rtab, trans, and subframe bushings
    An upgraded sway bar for front and rear is just a little too much money and is getting increasingly hard to find. Besides that what else am I forgetting?
  • It's Soda Not Pop
    • Jan 2022
    • 877
    Order all the bushings and mounts. Except for the front control arms just order new arms. Do your inner and outer tie rods. I used condorspeedshop for my bushings (delrin). I went solid but if don't want things hard mounted and you some play in your bushings, either go soft poly or oe rubber.
    There are a handful of companies that sell kits. Garagistics, Condorspeedshop, VAC, Powerflex, Revshift, FCP Euro, ETC.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • moatilliatta
      • 6151
      AKG bushings.
      @Zakspeed_US
      • roguetoaster
        Biggus Tippus
        • 7830
        Diff mount bushing, bolts for the lolipops, new dust caps for the new front strut mounts if yours are still original, shock bump stops and sway bar bushings.
        Skip the adjustable bar links.
        • J Holmes
          • Jan 2023
          • 4
          You will also need spring compressor tool. You can rent these from local auto parts store. A bench / table top vice is helpful. 21mm and 19mm ratcheting wrench is helpful. Get the lolipops with bushing pre-pressed in them. Saves some head ache. We chose to do new power steering lines while we were in there too one was leaking and figured it was time. Got all of ours from mix of Bimmer World, ECS Tuning and FCP Euro. At the end of Covid when supply chain so still crazy. Good luck.
          • RossfromAZ
            • Dec 2022
            • 16
            Pull-up RealOEM and order new hardware (bolts, nuts, etc.,) – the current stuff is almost guaranteed to be in rough shape.
            • It's Soda Not Pop
              • Jan 2022
              • 877
              CATuned has all new zinc plated hardware for everything
              88' Seta 2.7i Zinno
              • MasukBMW
                • Sep 2006
                • 325
                Here's a plug for standard stiffness replacement bushings. I did mine all delrin and regretted it due to stiffness (I daily'd the car). I drove a friends on stock replacements, much more enjoyable. Fresh stock versus 35 year old is a major improvement. Just consider what the car will be used for
                • roguetoaster
                  Biggus Tippus
                  • 7830
                  Agree. A street driven E30 seems to work much better with a softer suspension rather than a bouncy one, especially with modest/stock type power output. It's also a lot more forgiving while still being playful enough to enjoy.
                  • TobyB
                    • 5268
                    Agree for stock everything except the trailing arm bushings. I like the nylon in there better. The rear end's less vague.
                    But I also think the B8 is a very harsh shock. Too much high speed compression damping relative to everything else.
                    t
                    has opinions, but no filters.
                    • digger
                      • Nov 2005
                      • 6154
                      any good quality offset CABs that are a small step up from the OE solid ones? not look for hard as a rock but something a step up in stiffness that will last. i know that garagtastic is to be avoided but are there good quality ones? e.g AKG, powerflex?
                      • Ritzace
                        • Jan 2020
                        • 81
                        I would also like to know peoples thoughts on oem rubber vs soft poly, I've had some condor bushings in my ix and it was too much NVH.
