H&R Race springs spring pad questions...
  • digger
    • Nov 2005
    • 6199
    #31
    Originally posted by McGyver
    This really is the issue. I made my own camber/toe adjuster brackets to use e39 eccentric bolts. I thought I had a good idea of my alignment specs ahead of time, but my first attempt didn't allow for enough correction. I cut them off and tried again, which got my camber to a really good spot, but I've still got too much toe, which makes the car feel twitchy. I plan to try again when I swap in the new engine.
    i am interested to hear what you started with, how you setup/welded them and what didnt work out as i am embarking on this.
    The eccentric bolts have about +/-3 mm of adjustment. +/-3 mm over the 330 mm approx dimension is ~+/-0.5 degree.
    so i set mine the toe to the middle and i set the camber so that it can only be reduced only
    • McGyver
      • 4636
      #32
      Here's how I made the adjusters:
      I didn't explain how I welded them up, but i followed Garagistic's writeup. Basically, assemble the brackets with the bolts in the stock hole. Adjust the subframe so it's level. Turn the bolts to be opposite of what you want to achieve: if you want less camber, turn the bolts to be at most camber position so they can rotate to less camber once slotted. Rotate the adjuster brackets so they're level. Weld on the adjusters. Remove the bolts. Use a dremel to open up the hole into a slot that matched the adjuster brackets.
      I didn't get an alignment ahead of time, so I have no idea how much toe I had based on the shock/spring combo. I also haven't had an alignment in a long time to know what I ended up with. Max reduction in camber left a little negative camber, pretty much perfect. I think I originally went with toe in the middle, which didn't take out enough toe. I think I cut and re-welded for toe to take out the max from the starting position, this left a little more toe in than i'd like. It can be twitchy at highway speeds and in the rain, it also burns through rear tires, but evenly!
      • digger
        • Nov 2005
        • 6199
        #33
        Thanks. I am going to aim for about 1.0mm toe each side (supposed to improve stability c.f. zero toe or a bit toe out) and maybe 1 degree neg camber (improve inside edge tyre life), i hope my alignment shop gave good numbers and that the bushes werent flogged out enough to affect the validity of measurements.
        • McGyver
          • 4636
          #34
          When swap in the new engine (after I finish building it) I planned on re-doing the rear adjusters. I'll take it to an alignment shop to get the current measurements, maybe even get some measurements at different ride heights by swapping in some spring spacers I made. That should give me a good idea of how the alignment changes over a range of heights. I still need some advice on ideal alignment specs for street driven car that may see some occasional twistys or auto-x. I want the adjusters set up to allow for some actual adjustment, not just max out on removing negative camber and toe-in to get it close to good.
          • digger
            • Nov 2005
            • 6199
            #35
            From my research i am seeing for the rear on a RWD street car
            - around +2 to +3 mm (-0.080" to-0.125") total toe equivalent for ~16"
            - around -1* to -2* degrees camber
            the Bentley manual says
            - +3 mm +/-0.8 mm total toe (M-tech)
            - +2.6 mm +/-0.8 mm total toe (325i)
            - -2.5* +/- 0.5* (M-tech which seems high as i am 2.25* when quite a bit lower than factory mtech)
            - -2.25* +/- 0.5* (325i)
            Probably not going to matters much if you are somewhere in the range. You probably need to be way out to lunch or probably more importantly left to right imbalanced or suffering massive tyre wear to notice. Somewhere in that range is a start point.
            Mine has like a slight toe out atm and >0.5 degree LH to RH variation so hoping to notice something by rectifying that.
            • Vincent Vangool
              • Sep 2007
              • 16
              #36
              Originally posted by Northern
              Agree with the high pressure gas billies making the car ride stiffer. I think Konis and H&R Race should be a good combo, but I always tried to get the front lower and would bottom out my H&R Race setup. As long as OP is not trying to be 2010-era hellaflush, he should be fine.
              I'm also somewhat anti-skidplate... I ran raised motor mounts and never blew up an oil pan. Skidplate will definitely add some protection, but I think it also creates a feedback loop where it makes the lowest spot of the car lower -> you hit more stuff -> you are thankful you have a skidplate because "look at all it protected me from"y c
              I'm a big fan of the subframe risers. Maybe something is wrong with me/my car, but my wear was never bad on H&R Race even before subframe risers. Not a fan of the common adjustable subframe stuff due to slip and how many people seem to weld them on in a way that doesn't allow enough adjustment.
              I'm not going for 2010 hellaflush, hahaha. What mm risers would you put front and rear on this to get it to a good right height where I'm not smacking the pan? Mostly concerned with the front for now, as the rear will be easier to take apart and fine tune later. Any suggestion on front or rear sizes to accomplish this is appreciated.
              Any idea what size pads an 89 325is came with from the factory?
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                #37
                I think most rear subframe riser bushings are 12mm (+12mm diff spacers to bring the diff back down)
                If you mean engine mount spacers, I don't know. I bought some aftermarket engine mounts that were supposed to be stock sized, but they ended up being hilariously tall and unfortunately created more issues than they solved.
                Originally posted by priapism
                Originally posted by shameson
                • zaq123
                  • Jul 2016
                  • 1562
                  #38
                  digger, what springs are you using? On my rear subframe. I only installed toe adjusters when I was redoing my suspension (OEM BMW eccentric bolts kit). I placed toe adjusters in the middle and was at zero toe just as they ran out of the adjustment. I have H&R Sport springs with 10mm rear OEM spacer. Going to H&R OE Sports with 15mm E46 rear spring pad. We shall see.
                  Also I.m using these guys alignment tool (link). Had to buy some aluminium tubing for it and I/m using 20lbs braided fishing line as it's only 0.3mm thick and gives very accurate measurements. I got a bunch of those plastic kitchen thin cutting boards for wheels when doing the adjustment to keep wheels traction free. They are so slippery that I can slide the car sideways on them.
                  3D printed alignment kits that make professional race car alignments possible on even the tightest budgets.
                  • digger
                    • Nov 2005
                    • 6199
                    #39
                    https://calipergarage.com
                    i am running GC setup on rear so adjustable 2.5" perches 650lb springs 6" long. The most pertinent info is that it is a series 2 and ride height @ rear is 303mm centre of wheel to arch
                    • zaq123
                      • Jul 2016
                      • 1562
                      #40
                      ok I forgot what I did, I installed only camber plates in the rear, not toe plates. Figured it will slightly toe in on the mild drop but the camber would be more affected hence only camber plates....was I wrong? Let's say I pull trailing arms up on the camber adjusters up to get the camber in spec? Will arm geometry affect the toe in the neg (toe-in) or positive way (toe-out)?
                      • digger
                        • Nov 2005
                        • 6199
                        #41
                        This might help ?
                        BMW E30 M3 Performance - This site is dedicated to the BMW E30 M3. Covers tips on maintaining and modifying these unique cars.Installations of custom and aftermarket performance products are also highlighted.
                        • digger
                          • Nov 2005
                          • 6199
                          #42
                          it will toe in very slightly on compression but gain more camber
                          if your toe is ok now then it should be fine but excess toe in now gets a bit worse or if you have some toe out or straight then it wont change significantly to correct a "major" issue
                          what is your ride height centre of wheel to arch ? and what change are you looking for?
                          • zaq123
                            • Jul 2016
                            • 1562
                            #43
                            All subframe bushings are OEM. Rear ride height is 305mm now. I raised the suspension to OE Sport from Sport springs and ended up with 0.13 toe out on both sides (both sides have equal 1mm toe out on the string). Didn't measure camber yet. My previous setup when was slightly lower than now was zero toe and 1.8' (1'48") of equal camber on both sides (rear camber plates almost maxed out) . Id like to go back to zero toe. No toe plates, wonder if my camber plates will dial some toe as well since my camber is now is even less negative. I can also throw in 15mm rear spring pads in the back if it helps. That will bring my rear to 310mm?? (proportionate)?? ride height (I have 10mm pads now)
                            • digger
                              • Nov 2005
                              • 6199
                              #44
                              I dont think that lowering is going to correct 1mm per side without adjusters based on the numbers in e30sport.net
                              you can of course add 1mm offset OE rubber bushes (outer or inner/outer) if you don't want to add plates/eccentric bolt
                              or
                              the eccentric aftermarket pins with concentric poly bushes may be enough
                              • zaq123
                                • Jul 2016
                                • 1562
                                #45
                                or
                                strangely, I had it dialled ion perfectly when it was lower. I'm gonna see where my camber is at now because I think the camber adjuster has something to do with the toe being where it's at now.
                                looks like camber and toe plates do interfere with each other.
