Ground Control not sittin low in the front??
    • 34844
    ^ and afaik, IE plates are even taller than the stock ones.
    • e30this
      • 3580
      If I pulled it apart like you showed. Cut that bump stop then the shock would compress more.
      This still isnt allowing me any shock travel. In the end I see the only and best way to do it is to buy short koni and cut the tubes.
        • 34844
        or get shorter camber plates. the GC plates would give you at *least* an inch of travel at the same height you are right now.. without cuting and welding anything.
        • e30this
          • 3580
          Im going to be looking around. Thanks for all the help fellas...
          • 318isbmw
            • Nov 2005
            • 2843
            Good to know... Just called IE and cancelled my order and gonna spend the extra 25 on some gc camber plates.
            • rwh11385
              lance_entities
              • 18403
              +1. all these kids want to go through all the trouble to get those trick VW bodied konis and effort... when all you have to do is buy the right camber plates. Or like that dude Mucci whining about drop with stock strut mounts.
              wise.
              I run GC plates and have it waaaay too low without even trying. (My stock spring perches are still there btw as well!) Do it the normal and RIGHT way and you'll be fine. Sure, you could do the complicated way, but buying the right plates will be fine.
              And like Hellabad was pointing out, you can be just as low with billies... if you have the right camber plates. I just saw a slammed GC'ed ride yesterday rolling on billies.
              • z31maniac
                • 17566
                Like they all have said, I'm nearly tucking the fronts (215/40/17) and could probably take it down another 3/4" maybe a full 1".
                www.gutenparts.com
                • 884door
                  • Nov 2008
                  • 380
                  Nearly tucking? As in nearly tucking the whole tire/ some wheel?
                  • z31maniac
                    • 17566
                    Just the tire.
                    www.gutenparts.com
                    • e30this
                      • 3580
                      What camber plates are you running??
                      • Kilawin
                        • Dec 2005
                        • 994
                        GC camber plates and coilovers on this car. Non modified strut tube. Had about 1" left on coilover threads.
                        • e30this
                          • 3580
                          Thats exactly how I would like mine to sit. Well maybe 1/2 inch lower all the way around..
                          • Kilawin
                            • Dec 2005
                            • 994
                            Will diffinitely go lower.
                            • sticksdaman
                              • Apr 2005
                              • 2987
                              Thanks! there is hope yet!
                              Originally posted by ebelements
                              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
                              • Knockenwelle
                                • Jul 2008
                                • 395
                                Refer to my avatar and sig pics:
                                GC plates, coilovers, and springs, with 1.5" of drop left on all four adjusters.
                                Mike
                                '91 325i track car. Mostly...
