Bmw e30 ac schnitzer strut brace
  • rasco254
    • Aug 2014
    • 66
    I plan to install ac schnitzer strut brace on my e30 coupe but as per photo that the center bar seems longer approx 2 cm ...any one can inform me what to do? This car never have an bad accident before... is this e30 have 2 different strut center length?
    Sent from my SM-N9208 using Tapatalk
  • mr2peak
    • 2388
    Jack up one corner of the car, that will help spread the towers apart. It's supposed to be slightly long in order to preload the chassis
    Drive it hard. Maintain it well.
    A Topless Memorandum
    • Kershaw
      • 11822
      I'd think that jacking up one corner of the car would cause the body to bow inwards, making it closer. Wouldn't jacking it up in the middle, by the subframe / oil pan + block of wood cause the sides to droop? That might be enough.
      AWD > RWD
      • Stanley Rockafella
        • Aug 2011
        • 4062
        Originally posted by kershaw
        i'd think that jacking up one corner of the car would cause the body to bow inwards, making it closer. Wouldn't jacking it up in the middle, by the subframe / oil pan + block of wood cause the sides to droop? That might be enough.
        +1
        • YosemiteSam
          • Apr 2011
          • 1303
          +2
          • varg
            Florida Turbo Man
            • May 2014
            • 3431
            Originally posted by Kershaw
            oil pan
            Do not do
            IG @turbovarg
            '91 318is, M20 turbo
            • RobTapps88
              • Feb 2017
              • 137
              Originally posted by varg
              Do not do
              +1.. subframe only.
              Sent from my LG-H831 using Tapatalk
              • rasco254
                • Aug 2014
                • 66
                So how is the best methode .... the technician was affraid to jack the subframe and force the strut brace because they affraid that boy welding crack
                • RobTapps88
                  • Feb 2017
                  • 137
                  • reelizmpro
                    • 9558
                    Remove the brace from the top mounts, then install the center section of the brace. Jack up the front end so both wheels are off the ground with the top nuts removed then see if you can get the complete bar on little by little both sides at the same time.
                    88 M3 - LACHSSILBER
                    89 M3 - ALPINEWEISS II
                    • rasco254
                      • Aug 2014
                      • 66
                      Ok thanks
                      • NZM3
                        • Jun 2010
                        • 48
                        Hi, for sale on eBay.
                        https://www.ebay.com/itm/233093295345
