What are good spring lengths & rates for E30 Ground Control w/ M50
  • JGood
    • Jan 2004
    • 7959
    Originally posted by varg
    It blows my mind when people say H&R Race or similar is too stiff when I comfortably DD a car with 450lb/in front and 650lb/in back, and Koni SA shocks. I don't think you could go much higher than this with Koni SAs though unless you had them revalved.
    It’s completely subjective. I have 450/600 with Koni SA’s, UUC swaybars, and all new/urethane bushings on the entire chassis on my v8 e30. When I was 18, I would have said the ride quality is just fine. I’m 32 now, and it is in no way “comfortable”. Fun, yes. Easy on the back, no.
    Go to the e34 forums, this same discussion happens, but the guys complaining are doing so about H&R sports. I have that setup on my e34 and it feels like a Cadillac compared to my e30. It’s all relative, and subjective.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • varg
      Florida Turbo Man
      • May 2014
      • 3439
      Well of course it's subjective, but it really shows how used to the absolute marshmallow ride people are.
      IG @turbovarg
      '91 318is, M20 turbo
      • Tinkerer007
        • Mar 2013
        • 252
        Here in Sydney, they have a cafe to discuss such things...
        Sent from my VS995 using Tapatalk
        • Jb325is
          • 2137
          E34's are much more likely to bottom out the front strut than an e30, so usually the complaint is about crashing over sharp bumps in the front. 500/400 is a pretty nice all around setup for an e34
          - '88 m54 coupe
          <3
          • IRON-E
            • 16548
            24v swapped, run 450lbs, 6" springs out front & 5", 650lbs for the rear. A little bouncy at times, but the handling is awesome.
            @IRON-E30 aka Edwin:D
            • Northern
              I like cupcakes & sh!tboxes
              • 5284
              Same rates here with 24v/turbo/no AC and feels great on short Koni Race fronts and mustang rears. Sure it's stiff, but I find the stock suspension in most new cars to be more harsh.
              Originally posted by priapism
              Originally posted by shameson
              • So Live
                • 2512
                What length springs you guys using in the rear? I’ve got 4” 600lb springs on adjusters and the adjusters are too long and contacting the chassis. Could go with a stiffer spring which I probably will but I’m tempted to ditch the adjuster and just shim to the height I want.
                Basically who’s had success with what lengths without adjusters at a good low height?
                -Chris
                • Gas Gang Racing
                  • Jan 2016
                  • 7
                  So you can run 8 inch springs in the rear? I’m trying to figure out a good combo for my drag e30 build what height and rates do you guys think would work the best?
                  • So Live
                    • 2512
                    Maybe with a soft spring with weight transfer in mind... I think usually a 6” spring is as long as people go but haven’t gotten any good answers. I know 4” is too short (for me at least...) haha
                    -Chris
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3439
                      You aren't going to want a low rear end if you're running big slicks, so 8" should work fine. I'm running 5" rear springs with adjuster jacked the whole way up, probably 7" total height, and it's a stiff spring.
                      IG @turbovarg
                      • So Live
                        • 2512
                        Pics of ride height?
                        I’m on 4” springs with adjusters almost all the way up and I like the height but the adjusters are hitting the opposing spring seat (thankfully it’s UHMW Poly)... I also have an early model street driven car. Think I’m going to go with a stiffer 5” spring and see where that gets me.
                        -Chris
                        • varg
                          Florida Turbo Man
                          • May 2014
                          • 3439
                          There are some good pics in my project thread, link in my signature.
                          IG @turbovarg
                          • CMG
                            • Apr 2008
                            • 736
                            IMO somewhere around 6" give or take can work for front or rear, maybe max 7" front and min 5.5" rear. The good thing about coils is you can swap out springs pretty easily, so if you have springs in hand you can use em since you have them and accumulate different springs over time that will suit your preference. The only reason I can think of for using a longer spring like 8" is if it is progressive rate.
