Originally posted by Wishno87
View Post
This is a sticky topic.
Originally posted by Mystikal View PostSprings rates have little to do with ride quality actually. It's the dampers and tires that do the majority of the work. And with the Bilsteins, things will be pretty rough no matter what spring rate you go with.
Because of the aggressive rear offset, I'd go with 400/550 or similar. That's probably at the upper limit for what the dampers can handle, but I'd still shoot for that level of tension.
You won't need plates or anything else.
ok wheel guys. I am trying to pick up a set of 15x9 -6 with a rim depth of 107mm. they are the same size all around. will i need a spacer anywhere? And, if someone has some pictures of something similar in size on an e30, even if it is 16x9, that would be appreciated.
right now i have 15x8 et0 (sportmax) and they are slightly sunk so i think this new fitment will get rid of any sunkness.Last edited by omar85; 01-21-2010, 12:10 AM.
15x9 +7 will only be 5mm farther out then 15x8 ET0Need parts now? Need them cheap? steve@blunttech.com
www.gutenparts.com
this thread is a mess, and its pretty hard to search through, someone should put together a table.
anyhow i am looking for some wheels/tires for my 86 (full fender wells in rear) right now im considereing the LTW5s which are 15x7 et25. this will be used mostly on the street but possibly some dual duty (until i can get a second set of wheels). Id like to get as much tire on the ground, obviously, since im going to swap the 3.0l stroker into this car. recommendations please.
ThanksYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.
Just bought new wheels, they are 15x7 ET18. I was planning on using 205/55R15 tires on them. I'm runnig H&R Sports and Billstein Sports on an early model (high arches). These should be fine without any fender rolling or other craziness right?
I don't have the wheels in hand yet, but I would like to get some rubber coming so I can get everything together asap...Last edited by RainierHooker; 01-23-2010, 09:58 PM.
