This is a sticky topic.
  • tofubento
    • Dec 2008
    • 353
    #1831
    Whats with all the low offset wheel choices?
    Get some extended bolts and some huge ass spacers and mount up some good fitting wheels be adventerous roll those fenders!!!...oem for a 14 is like what...28offset? so why run a 17 with a 40 offset!
    This summer, once aero and suspension is done I am planning on running 15x9 0 offset all 4 corners...and most likely running some spacers.
    The 9mm is a .45 set on stun.:mrgreen:
    • tofubento
      • Dec 2008
      • 353
      #1832
      Mystikal,
      Tell me if my math is correct on this post I made on bimmerforums :
      linkage
      • Turf1600
        • 9815
        #1833
        Originally posted by Mystikal
        lol, should have guessed that.
        I just looked at Tirerack, and the news is bad. The two perfect tires for you would have been the Michelin Pilot Exalto (summer version) and the BFG KDW2, but BOTH have been discontinued in your size. That sucks.
        There are now very few choices for what you want. The BFG Traction T/A is good in the dry/wet and lasts literally forever, but it's not a 10/10ths performance tire. Perfectly fine for a daily and is very competitive in it's class, but it's no summer tire.
        If you want to give up some mileage the Falken 912 and the Fuzion ZRi are also good choices, and are a bit sportier (especially the ZRi). But they'll easily last half as long or less than the BFG.
        Here's the thing - I don't really care about performance. Just a good tire size and a tire that will last me a while. My car is a DD and I suck at driving anyways. How's the Ecsta ASX?
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #1834
          Originally posted by tofubento
          Mystikal,
          linkage
          lol, try to ignore Jordan (stuck). You're only feeding his hunger for arguments.
          Your math looked good, but I didn't read it all in detail. Serious disertation lengths going on.
          15x9 needs ET10 at the numerical highest in order to clear the suspension. It's pretty much paper-thin clearance to the front strut there. So go ET5 for safety. So from there you can figure out that 15x10 would need ET-7, etc.
          • Mystikal
            • 9602
            #1835
            Wicked.
            The ASX wears quickly, and isn't very good in the wet. I see it's cheap, but check discount tire direct for the ZE-912 pricing. It's better than the ASX in about every way, and you'll get the same mileage out of it.
            The BFG is pretty much exactly what you want though. The extra cost up front will more than balance out in the long run.
            • Turf1600
              • 9815
              #1836
              Wicked.
              So are we looking at a 205/55/15?
              • tofubento
                • Dec 2008
                • 353
                #1837
                Really?
                I did the math and with a 9 wide wheel with 15offset it looks like it would be the same hub to suspension fit....I think ill go with the zero offset then.
                • Turf1600
                  • 9815
                  #1838
                  Really?
                  Jordan was right on this one buddy.
                  • tofubento
                    • Dec 2008
                    • 353
                    #1839
                    Please explain and show me how...not trying to get an argument started...but I went through did a diagram, did the math, and even modeled it out... It should be correct...
                    If OEM wheel has 4inches towards hub to suspension, at 15offset that would still be 4inches from hub to suspension and leave me 5 inches towards fender. Total space allowed from hub to outer lip of fender is 5 inches...factoring in the drop and cambering it should be pretty damn flush. If thats incorrect please explain how, I am a bit puzzled how it wouldnt be.
                    Thank you!
                    • Turf1600
                      • 9815
                      #1840
                      Thank you!
                      Listen to what jordan was telling you and it will make more sense.
                      • tofubento
                        • Dec 2008
                        • 353
                        #1841
                        : face palm :
                        I did, we both went over it, he is saying it wont work due to me not calculating in half an inch per side...thats easy to navigate and fix...hmm the more I Think about it, maybe I should run a -5 HAHAHAHA!!! I am rolling the fenders anyways....hmmmm
                        • BoostMW
                          • Nov 2007
                          • 183
                          #1842
                          HI, I am buying some 16" xxr 513's offset 0 front and 15 rear, I don't wanna run a really narrow strechted lookin tire , How does 225/50's in front and 245/45's in the rear , thanks
                          • tofubento
                            • Dec 2008
                            • 353
                            #1843
                            whats the width of the wheel? 225 on a 9 has next to nothing for stretch...245 wont have any...though why such a huge sidewall?
                            • BoostMW
                              • Nov 2007
                              • 183
                              #1844
                              the width is 7 in front and 8 in rear, car has m30b35 engine with some bolt on mods so I need as much tire on the rear as i can fit on an 8 inch rim with 15 offset an a front tire sized to match with 0 offset
                              • Mystikal
                                • 9602
                                #1845
                                Yeah. 225/50/15 is only easily done with the ZE-912 (it runs 0.2-0.3" narrower than the rest), and you'll still need a slight fender roll in the back.
