This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #4051
    Originally posted by handysmurf59
    I want to run 4x100, 16x7.5 et35 RH ALLURAD wheels w/205-45-16 tires on my 1987 325iC that is sitting on a set of cabrio spect H&R sports. I test fitted a wheel and it just rubs the strut tower ever so slightly with the lugs tight. What size spacer do you guys recommend? I don't want to roll the fenders just move the wheel out a little.
    Thanks,
    Jason
    5mm is enough to clear the front stuts, but you'll want more to make those wheels look nice. 15mm front 20mm rear would be perfect.
    • Mystikal
      • 9602
      #4052
      Originally posted by dmoney(AB)
      alright, im puzzled
      I have a pair of Brock B1 17x8.5 et 13, they dont clear the stock brakes without a rather large spacer.
      I see Brock makes the same wheel but with a 35 offset. where will this position the wheel?
      I've used the offset calculator but I dont understand what they are saying.
      any help?
      Can't judge caliper clearance from the offset, as the change in offset can be achieved via various methods (hub could be shaved/smaller, spokes could be moved laterally, etc etc).
      That said, in general a +35 wheel with a 20mm spacer would be very likely to have more caliper clearance than a +13 version.
      • Mystikal
        • 9602
        #4053
        Originally posted by alpinee30m50
        I have an early model and am looking at diamond racing steelies, 16x8 up front with 195/45 tires and 16x10 rear with 215/45 tires. Im thinking 0 offset in front but im not sure what offset i should run in the rear. Its gonna be pretty dumped with rolled/pulled fenders and im trying to get it nice n flush, any advice on rear offset or anything else i should know?
        Go for 12mm in the rear, everything else sounds good. I'd go with 225/40 rear tires though, just to keep the diameters matching. 215/45 is a little tall to be pulled 10", aesthetically.
        • White325is
          • Oct 2006
          • 5947
          #4054
          Thank you VERY much for all your help in PMS. The wheels clear my front bags with ZERO problems and fit flawless. I wish I could buy you a beer.
          • dmoney(AB)
            • 1372
            #4055
            ^^^^^^^^ sick wheels
            Specs please!
            mtech1/2jzgte/r154/275tire
            function>form
            • White325is
              • Oct 2006
              • 5947
              #4056
              17x8 et 14 195/40 yoko s drives. have a very very slight stretch.
              • BenMGP
                • 210
                #4057
                I tried a search of this thread. Hope this isn't a repeat question, but probably is...
                I have D-Force 15x7 wheels now with 205/50 tires. I'd like to get the wheel closer to the fender without rolling fenders or deal with any rubbing. Any recommendations on spacer size?
                Thanks!
                • BenMGP
                  • 210
                  #4058
                  Thanks!
                  Going to try 20mm spacers all around. Ordered and on the way. Will report how it goes.
                  • alpinee30m50
                    • 647
                    #4059
                    So et0 up front and et12 out back, with 195/40 & 225/40 tires? Just makin sure i got everything straight here.
                    86 Zinno es
                    M50 inside
                    • White325is
                      • Oct 2006
                      • 5947
                      #4060
                      How about I help you since I already ran this setup.
                      16x10 rear with 6 inch back spacing. 215/45
                      16x8 front with 4.5 inch back spacing. 205/40
                      no rolling needed.
                      If you want more poke, then adjust from there.
                      This guys kinda running the same shit.
                      The general style discussion forum, as well as a place to post your car, or any car for that matter.
                      Theres also another guy on there with the same setup.
                      • Matt-B
                        The Waffler
                        • 3856
                        #4061
                        Mike thought you had BBs rs
                        • White325is
                          • Oct 2006
                          • 5947
                          #4062
                          Sold them for something different. ;)
                          • glucklich21
                            • 1912
                            #4063
                            So I have a set of BBS RA's that are 14"X6.25" with an offset of 30. The stock stud length is too short for me to mount them. The 45mm spare studs I have are too long (rubbing wheel hub innards). So, since I have the longer ones, what size spacer would I need to get an offset equivalent to like 25?
                            • csermonet47
                              • Jul 2009
                              • 937
                              #4064
                              What would be the best offset to run on a 16x9 wheel for a square setup. I have camber plates in the front, so I can adjust from there. I would be running a 215/45/16 as well. I don't mind a flat roll on the fenders, but would like to stay away from pulling them. I would like fitment close to this:
                              He is running 16x8s with +5 in the front, +3 in the rear and a 205/45/16.
                              Also, any recommendations for a 215/45/16 tire?
                              Thanks!
                              Are Three Vee
                              Dad Spec
                              • White325is
                                • Oct 2006
                                • 5947
                                #4065
                                16x9 et15 all around and a 10mm spacer in the rear should do the trick. Same setup I ran and it was pretty square.
