This is a sticky topic.
  • Jalves619
    • 596
    #3301
    Would 235/40r17 on 17x8.5 ET40 fit with roughly a 1.75in front 1.25in rear drop with rolled fenders or am I being too optimistic on what rolling can accomplish? I'm finishing up a 5lug swap and need to get some wheels and tires on there asap.
    E36 M3 Fronts H&R e30 Sports w/ 15mm Drophats
    MZ3 Rear H&R e30 Sports
    • psyber_0ptix
      • 904
      #3302
      that MZ3 rear is going to give you nightmares i'd imagine. They are far wider than the e30/318ti
      Originally posted by FredK
      However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
      My year in Germany
      Feedback
      • mcibmw533
        • Sep 2009
        • 20
        #3303
        I have an '84 325e that is soon to get UUC's bbk up front so I need to make room. I currently have a set of Sport Max 962's with tires mounted that are the following sizes:
        - Front: 17x7JJ 38 with 205/40 R17 80V tires
        - Rear: 17x9JJ 35 with 235/40 R17 90V tires
        Although I'm not the biggest fan of these wheels, I have them now and they're paid for.
        What needs to be done to make these fit? Based on a quick search it sounds like 15 or 20mm spacers? Do I need to roll the fenders for clearance (the car is currently on stock suspension but I plan to go to coilovers in the very near future with hopes of 1.5" - 2" drop)? Also, it appears these wheels don't have the same hubcentric size - are there spacers that will correct this?
        Thanks
        • E30_(1st Musk)_
          • 2008
          #3304
          For anyone running sportmax 501 16x8....would we have to get new lug bolts? or will the stock ones fit in there?
          • CpnSpankyPantz
            • 27
            #3305
            Originally posted by Mystikal
            You can easily fit 16x8s without rolling anything, just keep the offset 15-22 and the tires at 205.
            Hello, I've jsut signed up partly due to this thread!
            I'm from the UK and this info you've provided is great!
            I'm after some 16x8's available in et 25 and 10, so, from the info you have provided above, would I need 3mm spacers? They are available in et20 but not in the UK it seems!
            If I wanted to get the rears poking out a little would I need a spacer? Also, what size tyres would you recommend?
            Or, I've just had a look and I think you can get them in 16x7 et20...
            My car is a 318is which has been lowered 60mm at the front and 40mm at the back, the arches have been rolled a little, if I can get away with not rolling them further this would be even better!
            I'm currently running 205/55/r15's and due to the UK's bumpy roads the front arch used to catch every now and then - hence the rolling...
            Thanks in advance!
            • bimmer_E30
              • 5001
              #3306
              Hey,
              I found some set of wheels that i want to buy,
              35mm Offset in 15X7's...would they fit? what tire size?
              Originally posted by e30e
              • jdbmw325is
                • Dec 2009
                • 43
                #3307
                esm wheels the right offset?
                im thinking about getting these in a 16 inch by 7/5 or the silver ones like this. my question is what is the correct offset? discount tire said the +20 offset would be perfect. i just want to make sure that would work.
                the black ones come in these sizes.
                ►16x7.5 4x1002057.11.5"$175/wheel►16x7.55x1202072.61.5"$175/wheel►16x94x10010/2057.13.0"$275/wheel►16x95x1202072.63.0"$275/wheel
                the silver ones come in these sizes
                SizeBolt PatternOffsetCenter BoreLip SizeMSRP $ (USD) ►15x74x1002057.11.0"$150/wheel►16x7.54x1082057.11.5"$175/wheel►16x7.55x112 2057.11.5"$175/wheel►16x7.55x1202057.11.5"$175/wheel►16x7.5 4x100/4x1083573.11.5"$175/wheel►16x7.54x100/4x114.33573.11.5"$175/wheel►16x7.55x120/5x114.33573.11.5"$175/wheel►16x7.55x100/5x1123573.11.5"$175/wheel►16x94x1001057.13.0"$275/wheel►16x94x1082057.13.0"$275/wheel►16x95x1122057.13.0"$275/wheel►16x95x1002057.13.0"$275/wheel
                • badvibrations
                  • Feb 2007
                  • 447
                  #3308
                  1987 325is
                  H&R Sport
                  Bilstein Sports
                  15mm Drop hats
                  15x7 Rota Slips spaced from ET40 to ET20
                  Question is...
                  I want to run 225 50 15's(Falken Ziex 912 if brand matters)
                  Will I have rubbing issues without rolling the fenders?
                  Got a better tire size suggestion for the best looking wheel arch fill?
                  Thanks!
                  Mikey
                  Equal rights should be all or nothing, not picked and chosen based on what's convenient for ones personal agenda.
                  • theox69
                    • May 2008
                    • 1732
                    #3309
                    16x9 et11 all around, on coilovers.
                    What tire size can I run without rolling?
                    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
                    • Mystikal
                      Wheel Fitment Expert
                      • 9602
                      #3310
                      Originally posted by sefb222
                      well, im not opposed at all to rolling or even cutting the fender lip.
                      how wide do you think i CAN go, and avoid destroying my tires? 225?
                      Not a 225, as there are no worthwhile 225/40 tires made.
                      You're stuck with a 215 unless you're flaring bodywork.
                      • Mystikal
                        • 9602
                        #3311
                        Originally posted by mulberryras
                        i got a 91 325ic lowered 1 inch all around i like the wide tires look . i am looking at some 16 rims i am willing to do some fender roll,my question is , what is the best offset and rim size i can use to get the wide tire look? thanks
                        Wide tires? 16x8 +20 with a 225/45/16 is common. There's a 245/35 Toyo, but it's just too short to look right.
                        • Mystikal
                          • 9602
                          #3312
                          That's actually an ideal setup. The MZ3 rear I mean.
                          The fronts will be just about perfect, and the rears will actually be sunken in a bit. Contrary to popular belief, the MZ3 rear end has SHORTER shafts, which leads to wheels being LESS poked. You will need likely spacers to run those wheels back there, and you can use that to your advantage - get the wheels and tires, then measure to see exactly what kind of spacing you want. It's a little rudimentary, but you'll get exactly what you're looking for. Plus, I don't have much data on MZ3 rear ends on E30s at all. MR 325 has some good info from his car though, PM him.
                          • Mystikal
                            • 9602
                            #3313
                            Thanks
                            The funky tire sizes will look odd. Your front tires will be an inch shorter than the rears. Not saying it's a deal breaker, but you should be aware.
                            20mm front spacers are in order. As for the rears, you have some options. They should clear everything fine with a 10mm, but you can go down to a 5mm for more fender clearance and possibly bang in a bit of the inner well. It's a much easier job than rolling fender aggressively, as you don't have to worry about aesthetics.
                            For the hubs, just get hubcentric rings.
                            • Mystikal
                              • 9602
                              #3314
                              Thanks in advance!
                              Yes, to run the 16x8 +25 all around you'd need a 3mm front spacer.
                              Or, you can run those 16x7 +20s up front and use the 16x8 +25 in the rear with spacers at all. That should look great. You can even run a staggered 205/50 and 225/45 setup without any additional fender work.
                              • Mystikal
                                • 9602
                                #3315
                                Originally posted by bimmer_E30
                                Hey,
                                15mm spacers, 205/55 - 225/50 tires.
