This is a sticky topic.
  • e30lyf
    • May 2007
    • 4516
    #4471
    Originally posted by IronmanE30
    I have a set of 17 x 7.5 et 25 3 piece rims. What is the largest tire that will fit with minor fender rolling. The car is a 91 vert with H&R sport vert specific springs and Billy sports.
    I have also thought about going to a staggered set and running 8.5 wide rims in the back. I believe that will give me around an et 13 if I get 1" wider lips. Will this work and if so with what size tire?
    Cheers,
    Jim
    Hartge? :)
    - Fercy -
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
    • e30 gangsta
      • 3877
      #4472
      I am trying to achieve a bbs rs wheel that its final spec would be 16 by 9 +15.
      To do so I should look for a wheel with a high offset and maybe 7 inches wide?
      Im thinking a wheel thats 16 by 7 +45. So that you can have space to put bigger lips.
      Basically if you want big lips you need a high et? Then you measure the size of the lips
      that are currently on the wheel then order the new lips accordingly?
      For every 1" you add it takes the wheel -12 lower et off the wheel.
      For ever 0.5" you add it takes - 6 lower et off the wheel.
      Is this correct? Any help would be great im a noob at this bbs rs building.
      • IronmanE30
        • Sep 2009
        • 2121
        #4473
        Originally posted by e30lyf
        Hartge? :)
        Yes, Hartge 3 piece. :D
        I will need to refinish them but I finally found these after looking for them for over a year.
        Cheers,
        Jim
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #4474
          I'm going to go ahead and leave this here:
          0 offset wheels that are 8" wide or more have no place on an E30 without HEAVY fender work aka pulling/flaring. I'm not even answering these posts anymore. :)
          Now on to the rest...
          • Mystikal
            • 9602
            #4475
            Originally posted by brgracer
            Car : 91' 318i 4-door
            Wheels : custom 16x8
            Suspension : H&R Sport/Bilstein Sports
            Tires : ???
            Friend has a set of 16x8 custom wheels that he never finished as the centers have not been machined yet at all in terms of hub bore, bolt pattern, offset. Aside from the obvious 4x100 spacing, 57.1 center bore, what would the ideal offset be to fit without needing spacers/rolling etc...? I would like to run 225 width tires, but that is not set in stone. I'd rather run a 215 tire than have to roll/do fender work. Machinist said that there is enough metal to do anything from 0mm offset to 28mm offset, and he can obviously do diff offsets fronts/rears as well. Thanks in advance for any help.
            Think you phoned me regarding this, right?
            • Mystikal
              • 9602
              #4476
              Originally posted by PFCRayB
              i have look around and cant find what size adapters to run with vette salad shooters, the size is 16x9.5 all around, i cant remember the offset at the moment, i know i am goind to need at least 20mm if not larger, oo also ill be on low-tec 60 40 springs and billy sports, and the tire size on the vette wheels is 225 i think
              Ray
              Well you need a net offset of +5 to safely clear the front struts, then go maybe +0 on the rear to balance it out. You'll need SERIOUS, SERIOUS fender pulling and/or flares to pull them off. And about 3.5 degrees front camber, minimum.
              • Mystikal
                • 9602
                #4477
                Originally posted by baaaaaaa
                Im am wondering if konig remember wheels: 16x7, et20 would fit on my lowered e30. I have the H&R Sport, Bilstein suspension combo. Also what type of lug nuts would I need to run these wheels. Also wondering if you have any opinions on which wheels are better: konig remembers or esm 002's?
                Thanks
                They fit, 205/50 215/45 or 225/45 tires. Lug nuts you'll have to ask Konig.
                • Mystikal
                  • 9602
                  #4478
                  Originally posted by ACHTUNG
                  Paging Mr. Mystikal to the white courtesy phone:
                  Car: 1989 325i with no modifications to the fenders
                  Suspension: Bilstein HDs with IE stage 3 springs
                  I'm getting very close to pulling the trigger on a set of Schmidt Revolution Modern Line wheels. The options I'm struggling with are (here is where I need your input) -
                  Option 1: All 4 wheels 16x9 et15 4x100. Tunershop says these will fit fine with no rubbing and no spacers needed but...will there be any poke out from the fenders? Will the rears poke also? I want a flush look all around. Which leads me to...
                  Option 2: Fronts 7.5" et25 with 9" et15 rears. Would this give me more of a flush look or is it the same as the above option since the 7.5" fronts are et25?
                  What tire size do you recommend on the 9" on all 4 corners option and what tire sizes for the staggered setup option so there is no rubbing? I would like as much tire as possible.
                  Thank you
                  Tunershop should know that what they're selling (16x9 all around) does not fit without 3-5mm front spacers. The fronts will be poking, the rears not so much.
                  The staggered setup will need 20mm spacers to make the fronts fit remotely even to the rears.
                  215/45/16 Falken RT-615k or Kumho XS all around if you're worried about grip. On either setup.
                  • Mystikal
                    • 9602
                    #4479
                    Originally posted by kameleon
                    Car:- 1989 318I coupe
                    I am looking to get some 17's with a flush type fitment, and have been looking at the Team Dynamics Pro race 1.2 atm.
                    They have listings for:-
                    17x7 et35, 40, 45, 50
                    17x7.5 et15, 25, 30, 37, 45, 53
                    17x8 et20, 25, 33, 38, 40, 48, 53
                    17x9 et23, 27, 30, 35, 40, 45
                    I would rather have a decent sized rear tyre than super stretch.
                    With so many options i was looking at the 7 or 7.5 front in the 15-20 offsets and the rear i am quite unsure of atm.
                    What would you chose in my situation? (tyre sizing would be great too)
                    Theres are the wheels for reference. http://www.rimstock.co.uk/wheeldetail.php?id=44
                    17x8 +25 front and 17x9 +27 rear. 235/40/or 245/35 tires all around with a flat rear roll. Instant hotness.
                    • Mystikal
                      • 9602
                      #4480
                      Originally posted by russ in va
                      Any input on fitting a goodyear or hoosier 23x9x15 or 23x8x15 cantilever race slick under the car? My test fit of a 23x9 indicated that it would be tight but possible. I will probably go with the 8" wide tire just to make life easier. I'm thinking of using a 15x7 with 25mm offset. I think I would then need a 10mm spacer up front to keep the sidewall off the strut. Any thoughts? (In case you are not familiar with them, these tires, typically used in SCCA "Production" class racing, are specifically designed to mount on a 15x7 and are VERY wide through the cross section varying from 9.5" to 10.5" depending on which one you chose).
                      Those are massive. Your calculations are good, but if that thing goes past 10" section width you might need a correspondingly larger spacer.
                      • Mystikal
                        • 9602
                        #4481
                        Originally posted by Charley
                        I need a little more help. So I finally installed the 5 lug. And test fitted
                        both set of wheels I own in the rear with no springs in:
                        They poke almost the same like 1-3mm of difference. The Eccentrics are
                        set up to "stock" settings. So I can always add a little camber in the
                        rear but I don't have camber plates yet.
                        I want to run my old tires till I get enough funds to buy 5 new tires.
                        Actual tires are 205/50 and 215/40. Was planning on running 225/45 but
                        can't find anything under 150$/tire so changed my plans to 215/45
                        (Ecsta XS) Question is how far do I need to roll the fenders. And will it
                        fit well?
                        Thanks
                        Charley
                        Good tire choice. They should fit with just a flat roll in the rear.
                        • Mystikal
                          • 9602
                          #4482
                          Originally posted by GunMetalGrey
                          Rims: 17x7
                          Tires:205/45/17
                          Offset: 40
                          Suspension: JOM Coilovers
                          What spacer will I need to be pretty flush?
                          30mm front 40mm rear. I'm being serious. High offset + 7" width means you can't get those flush easily.
                          • Mystikal
                            • 9602
                            #4483
                            Originally posted by FrozenSolid
                            thinking of picking up a set of esm002 in 16x7.5 and 16x9 et20 all around. iam lowered on ie stg3. im currently running 215/40r17 (17x7 et25) and 245/35r17 (17x8.5 et25) no probs .
                            i also have another set of wheels that i want to put on the car. they are 17x7.5 et35 bbs rc. what spacers should i run and tires?
                            whats the best tire setup i can run. i dont want stretch/poke etc. most usable rubber in the back, iam willing to add a 15mm spring pad to help with any rubbing, the rear flares are already rolled. thanks
                            edit: couldnt wait lol ordered 2154017 star specs and 4 15mm spacers for the bbs.
                            You can also go 235/40/17 with the same spacers.
                            • Mystikal
                              • 9602
                              #4484
                              Originally posted by noahp45
                              Found a deal
                              Will 16x8 with +36 offset 4x100 lug pattern fit?
                              87 325i vert
                              15mm spacers all around.
                              • Mystikal
                                • 9602
                                #4485
                                Originally posted by bukaki_bob
                                I have a set of bbs rs's (16x8 et20) 061 and planning on running 215(or 225)/50/16's
                                suspension is bilstein and h&r sports
                                Would I need to run spacers in the back for a better stance?
                                The tire you're planning on running is much too tall.
                                205/50 215/45 and 225/45 all work.
                                Spacers will require smaller tires and rolled fenders. If flush fitment is your priority 205/45 and 10mm rear spacers.
