This is a sticky topic.
No wheel is ideal to run an 8mm spacer on with these cars. As I said, there is little to no hub left for the wheel to sit on. I wouldn't recommend installing them, but many have safely run them for years. Entirely up to you.Comment
Wheels: Azev A - et20 16x7.5
Tire Desired: N.A
Tire Size: N.A
Suspension: H&R Sport / Bilstein Sport
Chassis: 88 325is
I'm inquring about 225/45/16 size tires. Will there be rubbing of any kind? Body is all stock, fenders never rolled. Better bet to go 205/50/16? Mainly for daily driving & hard parking. :DComment
Hi mystikal,
Good day to you.
** Once again thank u..Comment
i have two sets of wheels.
whats the largest spacer i can use? i have front camberplates currently set at (-4). rear camber is at (-3) at its current height. should also mention adjustable height with 500f/600r springrates
wheel 1: (e34 style 5) 15x7 et20 with 195/50/15 tires. (need spacer for brake clearance in front)
wheel 2: (euroweaves) 15x7 et24 planning on 205/50/15Last edited by tonywonder; 09-24-2011, 11:10 PM.Comment
Can I add spacers to a 16x9 ET 15 with a 205/40 (rear) for a better stance?Comment
From looking through all the post it seems the widest tire people are running is 245's.
I'm wondering if anyone runs wider than this?
If so, what kind of offset are you running? What suspension?
My question is because i'm building a ls1 car that will be putting down atleast 400rwhp.
EDIT: Car is a 1987 325ISComment
1991 318is
BBS RS 039 /// 16x7 et 24 front.. what size spacer and optimal tire size.
BBS RS 040 /// 16x8 et 24 rear.. same question as above.
Also, I need to get some hubcentric rings.. what is the best way to find out the correct size?
Thanks!Comment
