This is a sticky topic.
  • mrmckie
    • 728
    #5011
    F:17x7 +35, R: 17x9 +35, 4x100
    I'm pretty sure the front will be fine but will there be any rubbing issues in the rear??
    "I came into this world, not chiefly to make this a good place to live in, but to live in it, be it good or bad" -Henry Thoreau-
    1991 318is - the cruiser
    1989 325i - the rats nest
    • Mystikal
      Wheel Fitment Expert
      • 9602
      #5012
      Originally posted by mikejungle
      I would like added the added performance that wheels farther out would provide, but I think it can look silly sometimes.
      I am not against the idea of rolling my fenders at all; in fact, i saw a set of rolled fenders where the crease/bevel was taken out and the fenders were allowed to flare out to a paper-like edge...does that make sense? I thought it looked pretty good.
      I'm having trouble finding 25 mm spacers for a decent price, but I found a pair of hub-centric 20 mm for 60.
      can you suggest good cheap brands/retailers, or is any spacer pretty much as good as the next?
      Stick to 20mm front 15mm rear then. As long as the spacer is machined properly, has a hubcentric lip set at 57mm....you're good.
      • Mystikal
        • 9602
        #5013
        Originally posted by kreasims
        17x8.5 et 17 and 17x10 et 19
        Will it fit late model E30?
        Tyre size recommendation?
        Thanks Jay
        Yes, with a decent rear spring rate as well as slightly pulled fenders.
        205/40 F 225/35 R
        • Mystikal
          • 9602
          #5014
          Originally posted by jim325
          16x8 et26. I will have to use hubcentric rings because the center bore is 73.1mm. Should I get any spacers?
          I already have a set of tires that id like to use. I am pretty sure they are 205/50r16. Will they rub? Will the tires be too stretched?
          The current wheels I have, 16x7.5 et23 do not rub. BUT I already rolled my fenders.
          You will need 5mm spacers to clear the front struts. 205/50 will be fine, you can go yp to 225/45 later on without issue.
          • Mystikal
            • 9602
            #5015
            It will probably bolt up but won't look that great (fronts will be far sunken in). 15mm front spacers will solve that. You can use 205/45/17 F 235/40/17 R.
            • mrmckie
              • 728
              #5016
              sweet, i think i might get them then..this is steal.
              • R3Z3N
                • Jan 2011
                • 3056
                #5017
                So I have a 5 lug swapped car: E36M3 front, 318ti rear. Wheel wells have been rolled and slightly pulled. Currently: Wheel specs are Bbs RS 262 front (17x8 et 35 with 215/40/17) and Bbs RS 263 rear (17x9 et 35 with 235/40/17). Rears are slightly tucked and only rub on big bumps under acceleration.
                Want a good autoX setup, preferably something shorter to gain back gearing (even though I have an S52....) and so the car will sit lower. Thinking 8s all around would be fine, because I am not sure if 9s will work up front. Need 16s or 17s (preferably 16s...) Suggestions? Would like to stick with Hankook RS3s or Star Specs....
                225s min up front also.... would prefer not staggered...
                • mikejungle
                  • Apr 2007
                  • 361
                  #5018
                  Can you tell me why you suggested bolt on spacers? Is it because the thick ones need it?
                  and if you think the 25/20 would look good without being "stanced" (am i using that right?) or too flush, i'm good with it. i'd flare my fenders for it if it will handle better. why did you change your opinion to 20/15 based on what i said?
                  thanks for the advice.
                  1985 325e
                  mods:
                  Powerflex CABs
                  MOMO Corse Exhaust
                  euro bumpers with BBS front spoiler
                  e36 m3 shifter
                  uuc clutch stop
                  • brutus87
                    • 6280
                    #5019
                    Car: 1988 325i late model
                    Wheels: BBS RS 16x7 et19 4x100 square set.
                    Will the fitment be good?
                    Im on ie3 springs with konis.
                    Do I need any fender work ie rolling/pulling?
                    I have euroweaves(15x7 et 24) on right now.
                    What size tires would best for this setup?
                    Thanks for your time, you are awesome :)
                    • kreasims
                      • Jan 2009
                      • 149
                      #5020
                      205/40 F 225/35 R
                      Thanks Jay :D
                      • aje28
                        • 572
                        #5021
                        BBS Style 5's 17x8 ET20
                        4x100 to 5x120 adapters 18mm
                        205/45/17
                        Will it fit a early model e30? What size adapters do you recommend? Thanks
                        • aknickintyme
                          • May 2011
                          • 33
                          #5022
                          just picked up a set of porsche design 90's for my e30
                          16's x 7.5 +65
                          16's x 9 + 52
                          i was wondering if you could give me some recommendations on adaptor thickness..
                          my car is an 86 325 es..
                          im aiming for a flush look in the front, & some nice poke for the rear..
                          ecstuning has some 25mm & 35mm H&R adaptors available
                          i also heard good things about adaptec Speedware..
                          i was thinking about running 35mm's up front
                          and 25mm's in the rears..
                          what you think?
                          heres a picture of my car
                          [/QUOTE]
                          i want my wheels to look just like this....
                          from this picture i think i might have to run 35mm adaptors all around?
                          as for tires i plan to use
                          205/40/16 up front
                          215/40/16 in the rears..
                          i actually havent gotten suspension but
                          i plan to order some ground control coilovers ass soon as i get the chance..i just need to figure out what spring rates will work best for my car..
                          • danielmp
                            • Dec 2010
                            • 285
                            #5023
                            Falken 912 on BBS RZ
                            Just wanted to run my plan by an expert:
                            1990 325i on H&R sports, Bilstein sports.
                            I've purchased a set of BBS RZ378 - 15x7 et 20
                            I'm planning on buying a set of Falken ziex ze-912 in 225/50/15.
                            Just wanted to verify this will fit without rubbing, I don't want to roll the fenders. Are the 912s a better tire than the 512s? - Looking for a good all-season tire for my daily driver, will see a decent amount of rain and only vry rare snow. Thanks for the help.
                            • BenMGP
                              • 210
                              #5024
                              I am running 205/50/15 on D-Spec wheels et25 with 20mm spacers are the way around with no issues. Rolled fenders.
                              I am going with a 2.7 build and want to remove the spacers and go wider. Recommendations?
                              I would not mind going with a taller tire as I've already been through 2 oil pans.
                              Thanks.
                              • Mystikal
                                • 9602
                                #5025
                                You'll have to go with 17s for tire selection. Something close to 17x8.5 +40 all around will take a 235/40. May need a 3mm front spacer depending on what front suspension you're using.
