I am thinking of going for ESM Wheels for my 86 Euro Coupe.. someone here has 2 16x8 ET 20 and 2 16x8 ET 15 for sale , would these work? I am currently using 16x7 wheels with 2 week old 205/50/16 tires and want to know if the ESM wheels will fit and if i can reuse the tires i have.
Yes, to re-use the tires a rear fender roll is necessary. Not needed for a 205/45.
I've got a late model e30, I will be running h&r sports or eibach pro springs, the wheel I want to run is a MSR 228, two options
1. 15x8 et 25 all four wheels with 205/50/15
2. 15x8 et 25 fronts and 15x9 et 15 rears, tires?
I would like to run something like a 205 50 15 tire, what tire combo would be best for the staggered set up and would any spacers or fender rolling needn to be done? Thanks!
Needs 3mm front spacers to clear the struts. First setup is perfect, no rolling. Second setup would need 205/50 rear tires and may need a fender roll depending on height.
I have a late model e30 with a 5 lug swap; z3m rear, e36 m3 front tc kline coilovers. Now the problem is I like the way 16" wheels look better than 17" my problem is clearing the m3 calipers up front. I have very little wheel knowledge especially when it comes to fitment. Ideally I'd like to run some sort of mesh wheel such as hre, hayashi, epsilon or ideally bbs e50s.
My main question, is will any of these wheels clear the calipers up front?
Or what do I need to do to get them to fit?
Keep in mind I haven't started looking yet as I have no idea what to look for, and I am not 100% set on any particular wheel. Any input would be greatly appreciated.
I know off the top of my head about 8 16" wheels that clear E36 M3 brakes and the only one possibly of interest to you are BBS RS. The rest, no idea.
Just got a 318i 1985. Going to throw raceland coils on it(know they aren't that great) Planning to get DR steelies. In the front ,16×8 ET 0 195/40 yokohama S.drives. In the rear 16×10 ET 0 215/40 yokohama S.Drives. Will this setup be fine with just rolling of fenders? Should the rear be 0 or 12 ET? I Don't want to have to run camber. Sorry I don't know alot about fitment. Any recommendations on setup would be appreciated. Thanks!
5x114.3
16x7.5 +45 x2
16x7.5 +35 x2 bbs rs'
will these fit on my 318 with adapters?
Not sure what model rs's they are.
Would want to be able to run them with a 205 width tire if possible.
Yup, they're about ideal with 25mm adapters. Use 205/45 all around.
i have some 16x7 et 23 after adapters the effective offset will be 3 how will these sit? and whats a good tire size? i can go to 1.5inch adapters will it sit like a 16x8 et0 with those?
195/45, should work. Don't space them any more than 20mm.
