This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #6211
    Originally posted by Wrinckled
    Thank you for the fast reply, what's the highest safe offset (insuring I don't rub strut or brakes?) I'm worried that 55mm adapters is too large (a bit unsafe)
    40mm minimum. I've run 52mm of stacked spacers/adapters on each side for 10k+ miles you'll be fine.
    • Mystikal
      • 9602
      #6212
      Originally posted by darvo
      What tires I could use using 1.25" fender flares and 1.5" rears, with 17x9 et0 wheels?
      Meatier the better....
      You'd be better off with the +25 version and spacers. 15mm front spacers to clear the struts and nothing in the rear. 245/40 all around should work well.
      • turboaddiction
        • Sep 2012
        • 28
        #6213
        Im looking at some 16x8 +15 wheels how much fender rolling would i need to make 225/45/16 tires fit? If its going to take a lot a may just run 205/50/16s. The car just gets driven spiritedly but will be turboed soon so in the future i will be looking at fitting as wide and sticky of tires as i can.
        Thanks for any help
        Turbo
        =The Daily= 05 mailbu classic ok mpg and comfy auto commuter
        =The Toy= 1990 325i sedan waiting for boost
        =4x4 Status= 1999 Toyota 4Runner limited
        =Gone but not forgotten= 98 impreza RS with JDM 97 STi swap and 4.444 gearing, 04 Neon SRT-4 big turbo 420whp at 24psi,
        Slammed 89 dodge d100 long wheel base.
        All modifyed cars built by me I dont do things the easy way.
        • Sputnik
          • Jan 2010
          • 808
          #6214
          With Euroweaves, on a car with a hr sport suspension, what is the widest spacer I can run front and rear without rolling fenders?
          • Mystikal
            • 9602
            #6215
            Thanks for any help
            Turbo
            Flat roll and stiff spring rates (500lb+) should do it.
            • Mystikal
              • 9602
              #6216
              With 205/55s 10mm rear is probably the max. The front you can do much more but that would look silly.
              • archie
                • 5448
                #6217
                What wheels are these? I see Euro in the cap but cant tell the world just below it.
                Thanks
                88 M3 Diamantschwarz
                89 M3 Zinnoberrot
                56 Isetta
                LIKE ARCHIE'S on Facebook!
                • JC-E30
                  • Nov 2012
                  • 56
                  #6218
                  Hey there,
                  I'm trying to decide what wheel set up to go. I'm pretty good with the offset situation, but I'm wondering on the actual weight.
                  How heavy is too heavy? Being an M42 with not much poke anyway, I don't want to compromise it any further.
                  Looking at either 16inch or 17inch wheels. I currently have some on there that are 16lbs. The stock 14 inch wheels are only 14lbs.
                  • esthero
                    • Feb 2013
                    • 6
                    #6219
                    hi guys,
                    just got myself the m-system I 17x8 et 20 front and 17x9 et 22 rear. Can't decide what is the widest tire setup i can run without having to roll the fender and add spacer.
                    • Mystikal
                      • 9602
                      #6220
                      Originally posted by JC-E30
                      Hey there,
                      Lighter the better. Although tire choice has a much larger impact on driving feel and performance than unsprung weight, IMO.
                      • Mystikal
                        • 9602
                        #6221
                        Originally posted by esthero
                        hi guys,
                        Car?
                        • JC-E30
                          • Nov 2012
                          • 56
                          #6222
                          Thanks mate... although I was more curious to what is too heavy. Ie is 16 - 18lbs a "heavy" wheel for an E30. I know in modern cars which come standard with bigger wheels, they say anything under 20lbs is good...
                          • esthero
                            • Feb 2013
                            • 6
                            #6223
                            Originally posted by Mystikal
                            Car?
                            it's an e30 re-drilled to 5x120 on Sachs spring and billstein shocks. :)
                            • Mystikal
                              • 9602
                              #6224
                              There's no such number, anyone who states a set weight figure is making it up really. Lighter = better.
                              • Mystikal
                                • 9602
                                #6225
                                So stock E30 hubs redrilled, right? 215/40 is the widest you'll fit without fender rolling and even then it will be tight in the rear on an 88+ car.
