This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #6571
    Originally posted by e30lyf
    Hey Jay,
    16x8.5 et20 (F) and 16x9 et14 (R). i am running IE3,drop hats & koni sport.
    do i need to run front spacer? 205/45/16 would be perfect size? really appreciated your opinion.. :)
    3mm front spacer likely needed but I'd test it without first. 205/45s are perfect.
    • Mystikal
      • 9602
      #6572
      Originally posted by matthugie
      With Apex Arc-8's do 235's fit in the front as is or do they require rolling? Most of the questions I found in this thread were in regards to the rears, but my rear fenders are already rolled so the front is my only concern in running square 235's. Thanks!
      No rolling the fronts.
      • e34_spangler
        • Dec 2012
        • 314
        #6573
        Originally posted by Mystikal
        No.
        Ok thanks alot dude i appreciate it!
        • hopeful
          • Dec 2012
          • 109
          #6574
          exactly, z06 wheels. I've got a 325i sitting in my garage, and .... yah ummm lets see... Anywhos, ive got a thought I wanted to run by you about wheel offset and get your input.
          ...if the wheel offset is very different from stock, would that cause unneccessary axial loading of wheel bearings? causing unwanted thrust forces which increase rolling resistance and also reduce bearing life? I don't have a source or anything on this just something I was thinking and wanted to see if you (or others) think the same.
          • E30nub1
            • 402
            #6575
            Noob to tire staggering here......OK doing a suspension upgrade.. i have a set of 215/50/16 in the fronts that have less than 200 miles on them so obviously no need to replace these and i don't want to buy a brand new set of 4.. So what size would be a good call for the rear for a good stagger
            sigpic"God made cars to be RWD and standard"
            • ajackz
              • Apr 2012
              • 252
              #6576
              Suspension on the car
              KW 60/40 lowering springs with kw struts and shocks.
              Wheels
              15x8 offset 19
              Will 225/50/15 fit with out having to roll or pull fenders?
              I can't decide if I should run all season
              225/50/15 or Summer tires in 205/50/15
              Money is keeping me from 225/45/15
              I'm cooler in person.
              • lambo
                Captain Scene Points
                • 10953
                #6577
                Spacing out wheels does add extra stress on wheel bearings.
                • Mystikal
                  • 9602
                  #6578
                  It's funny. I just bought a set of those same wheels, that's why I knew the dimensions so quickly. Picking them up Saturday.
                  If the geometry ends up the same I'm one to believe the load on the axle/hub/etc remains the same. For example a +35 wheel with a 15mm spacer does NOT provide any additional stress than a +20 wheel. I've read every argument for both sides and stay firmly planted in this camp.
                  • Mystikal
                    • 9602
                    #6579
                    There isn't. The fronts are already oversized in diameter, there's no suitable rear that will look right and actually fit.
                    • Mystikal
                      • 9602
                      #6580
                      Wheels
                      15x8 offset 19
                      Roll 100% needed. Use 205/50s.
                      • keefy6
                        • May 2011
                        • 991
                        #6581
                        Hey, need your help again. The wheel is 17x8.5 et 13 5x120
                        What tire spacer combo do I need to fit?
                        My old Style 5 Thread / My Swap
                        1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
                        IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
                        1998 528I (Sold) // 2003 540I ///M Sport
                        • hopeful
                          • Dec 2012
                          • 109
                          #6582
                          their super cheap eh? 1000$ for very high qual stuff, what are you putting them on?
                          • dannyyisntt
                            • 3141
                            #6583
                            Car is soon to be lowered on FA coilovers so I've been wheel shopping..
                            16x8 et12 and 16x9 et12
                            What tire sizes should I run? I'd like to stick with a very mild stretch. Also will it take much fender work to make them fit?
                            • Mystikal
                              • 9602
                              #6584
                              Without 5-lug conversion those aren't going to work.
                              • Mystikal
                                • 9602
                                #6585
                                Car in sig. With 315 tires to boot. ;)
