This is a sticky topic.
    i wanna just know the most backspacing for front and back with a 17inch rim?? i got a late model, on coilovers(joms) but switching to better ones.
      Alright, lets try this again... the right way.
      1987 325es
      Final tire choice:
      Toyo R888 in 255/50r16
      Wheel can be a 16x8 or 16x9.
      Would like to avoid flares, but will be doing some SERIOUS fender pulling/modding/shaping.
      What's the best offset?
        Mystikal - I know this is e30 specific, but do you have any M3 experience?
        I'm wondering what the lowest offset I can safely run 225/45/16 on 16x7.5 wheels. Would et07 be rub city on the front?
          Answered my own question. I totally forgot I had a factory E28 M5 spare tire in my E28's trunk, so a bit of test fitting.
          Specs:
          16x7.5
          et 20
          225/50/16
          10mm spacer
          The tires are obviously too tall, but the pacing doesn't look to be bad.
          DSC_8477 by ericandshovin, on Flickr
          DSC_8478 by ericandshovin, on Flickr
            Looking into a new setup for autoX this summer. Car is an 87 325is, GC coils that are currently way too low but will be fixing that.
            I know 15x8 TRM C1's with 225/45 Hankook RS3's are a tried and true combo, they require just a bit of fender rolling, correct?
            Also looking into 15x9's, wheel in particular is 15x9 et15, again with 225/45 RS3. What sort of spacers/fender work would that require? Thanks.
              Will 17x9 et20 work on a 87 325is with blitztein HD and vogtland springs? Will it clear brakes? Fender roll? Tire suggestions? I'd say its 1.5-3" below stock height gestimate
                Originally posted by AWDBOB View Post
                Sorry, man. No flares currently on the 1989 325es. Suspension isn't slammed.
                There's no such car, but okay. +25 is a good rear offset for a large tire on a 16x9. If that tire size is available, it would require metal cutting and flares.
                  Originally posted by mohamed... View Post
                  i have 2 sets of wheels.one is a set of 17x8/9 style 32s with an offset of 26/20 and then a set of 17x8 e39 style 5s with an offset of 20. i will have e30 m3 rear 5 lug and then lativian spindle sleeves which widen the front by 12mm on each side. my question is can i run 235/40/17 all around on both sets? i am on ground controls and all the fenders will be roller. thanks!
                  215/40 is the limit all around with either setup. Maybe 235/40 rear only if it's an early car.
                    1987 325es
                    Final tire choice:
                    That's over an inch too tall to ever work on stock fenders.
                      Specs:
                      16x7.5
                      et 20
                      225/50/16
                      10mm spacer
                      LOL, well done Eric. Yes that should work with 225/45s.
                        First setup likely wouldn't require a roll on your car, good fit. The second setup would definitely require rolling, but can work. 3-5mm front spacers may be needed depending on your front spring setup.
                          Hello again,
                          Mystikal here is the wheel dimensions
                          16X7.5" et13 BBS RZ
                          offset +13
                          I'd like to have them redrilled; what spacer will be needed if any and recommended tire size?
                          My old Style 5 Thread / My Swap
                          1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
                          IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
                          1998 528I (Sold) // 2003 540I ///M Sport
                            10mm front spacers, 205/40 all around. Won't need a fender roll.
                              Originally posted by keefy6 View Post
                              Hello again,
                              16X7.5" et13 BBS RZ
                              offset +13
                              No spacers, 205/45/16 tires. Will just clear without rolling.
                                Hey,
                                I'm looking to a set of RM's. Just wondering which offset will get me flush with the fenders - 3" lips et1 or 2.5" lips et14. Or is staggered the preferred method?
                                EDIT: Nevermind, sorry I should have searched THIS thread before asking - looked through google and other threads. I now have my answers.
                                Thanks!
                                1987 325 | @e30_hunter |
