This is a sticky topic.
    89 325is - Lowered on IE Stage 3 - Fenders not rolled
    16x7.5 ET35
    Tire size? Also, what spacers would be required and what would be ideal?
      Originally posted by Tom. View Post
      I just picked up some 15x7 et20 wheels. fronts don't clear the caliper, so I know I'll need spacers there. I'm still undecided on tire size, I just run FK lowering springs and KYB struts.
      is this a forgiving offset? seems like my options on tires are 205/50, 205/55, or 225/50?
      anyone have any input at all on potential wheel gap, or spacer recommendations?
      Can't answer you without knowing how much spacer you need to clear the caliper. And you'll have to figure that out on your own.
        Originally posted by dubtechnic View Post
        I've been thinking of picking up a set of e38 style 5's. 16x8 et 23. Not sure what tire combo to run yet although I don't plan on having anything stretched. Car is going to be on Koni adjustables and h&r sports. It's an mtech2 92' 325i vert. I've been on the white stock weaves for a while now and wanting to get into a wide size wheel. Recommendations on a sport/street setup with these wheels?
        Redrill? Adapters? 5lug?
          Originally posted by e30lyf View Post
          Hi!
          16x9 et15 square set up with IE3,Koni & Drop hats. I am getting coilover anytime soon.
          what tire size would you recommend for late model? appreciated
          Thanks,
          3-5mm front spacers and 205/45/16s. This works without fender work. Roll your rear fenders and add spacers later to taste.
            16x7.5 ET35
            Option 1: 15mm spacers all around and 225/45s
            Option 2: 15mm F / 20mm R and 205/45s
              im going with adapters, either 18 all around or 18 front 20 back, most likely the latter.
                The wheels are not for you then. The fitment is aggressive and requires stretched tires and fender rolling.
                  I was planning on fender rolling if it became necessary. You think a 225/45 tire will rub with this setup?
                    im looking into a set of 15x8.5 et17 but Im not sure what size tires to go with? The car is not lowered and probably wont be.
                    -Nick
                    Originally posted by 87e30
                    First of all: calm the fuck down; second of all; cool story bro.
                      thanks for the quick responce.. :)
                      i might get another set of wheels 16x8.5 et25 square. do i need front & rear spacer? i guess the best tire size 205/45. TIA
                      - Fercy -
                      Classic BMW Specialists
                      Santa Clarita, CA
                      www.BimmerHeads.com
                        Yes.
                          205/50 for clearance reasons.
                            Yes, 12-15mm all around would be nice.
                              17x8 et15 was thinking 225/40/17 up front and possibly 235/40/17 in the rear? Or should just stay 225/40's all round? Going on a late 88' touring. Plan on running fairly low and already have rolled and slightly pulled guards.
                              E30 325i Touring currently under construction.
                              http://www.r3vlimited.com/board/show...256444&page=20
                                215/40 is your limit. 225/40 doesn't really exist AFAIK.
