This is a sticky topic.
  • bmwandhonda
    • 646
    #6646
    Originally posted by Mystikal
    215/40 is your limit. 225/40 doesn't really exist AFAIK.
    Yep you are right. Seems like only a few semi slicks in that size :/
    235's have scrubbing issues I assume?
    215's should be fine. Thanks mate
    E30 325i Touring currently under construction.
    http://www.r3vlimited.com/board/show...256444&page=20
    • flash 23
      • 904
      #6647
      OK need some input. wheels are 16x8 et11 (front) and 16x10 et23 (RS all around).
      Had a set of 5x120 16x8 et11 filled/redrilled to 4x100 before, but the wheel place shaved the back pad to even(flatten it) out and I kinda didn't like that.
      Now my question, can I get away with doing an adapter on rear 18mm adapter (4x100 to 5x114.3) to a final ET of +5 even if it's 10"?
      what do you suppose I should do with the front wheels? TIA
      • brutus87
        • 6280
        #6648
        William need to roll or pull, or spacers for:
        Also, tire size?
        Late model coupe with 15x8 et13 BBS RM?
        Thanks!
        • Mystikal
          Wheel Fitment Expert
          • 9602
          #6649
          No, the rear offset is close to where you want it without adapters.
          • Mystikal
            • 9602
            #6650
            Also, tire size?
            Thanks!
            You should just be able to clear a 205/50. Rear roll may be necessary if you're really low.
            • tommyp
              • 112
              #6651
              15x6 front and 15x7 rear ET13 on all 4. I currently run 195/65/14 on my winter wheels with no issues and I like the meaty look. I am thinking 195/60/15 for the new wheels. Is this a good option? Car is lowered approx 1.5-2 inches and all four fenders are rolled.
              • reelizmpro
                • 9469
                #6652
                I decided to order up some 18mm adapters so I can run my 5x120 wheels on my M tech vert.
                Front is 17x8 ET 20 - 18mm net offset +2
                Rear is 17x9 ET 26 -18mm net offset +8
                I want to run at least 215/40 on the 9's so I can still use them on my other cars. Suspension is H&R Race springs/Bilstein sports. I figure I can stack more spring pads in the rear to add height if needed. What do you guys think? All feedback is appreciated.
                88 M3 - LACHSSILBER/SCHWARZE
                • mccor023
                  • Jul 2011
                  • 683
                  #6653
                  I am sure its been asked, but:
                  I have a lowered 89 coupe w/ Ronal LS 15x7.5 et25 and 225/15 tires.
                  I didn't have to roll fenders, but believe I have some rubbing in the front.
                  I'm assuming its on the strut because it only happens during low speed turns.
                  I found 3mm spacers, but is it a problem to run them just in front or should I get a pair for the rear also?
                  Is it necessary to spend the extra money for the 3mm longer bolts, or would stock bolts work fine?
                  Thanks
                  I love that people ask stupid questions so I dont have.
                  • E30nub1
                    • 402
                    #6654
                    There isn't. The fronts are already oversized in diameter, there's no suitable rear that will look right and actually fit.
                    thanks for the input i decided to go with 205/45/16 all around
                    sigpic"God made cars to be RWD and standard"
                    • trashycamaro
                      • Feb 2011
                      • 70
                      #6655
                      Hey guys, quick question. I have the OEM bottlecap wheels on all 4 corners and stock suspension, which will all be staying as is for now. It seems the stock size for tires is 195-65-14 and the PO had 215-60-14 on there.
                      I need to replace two of the tires and I am looking for great rain performance without regard to snow (MIAMI!!). I see there is a lack of options in the two sizes above, but it looks like 195-60-14 would work.
                      Any recommendations to other sizes and to specific tires for the car for wet traction?
                      Thanks!
                      - Dan
                      1991 e31 - Black on Black, 5.0L/6 Speed. Sold
                      1990 e30 Cabriolet, 2.5L/auto. Sold
                      1999 e39 Touring, 2.8L/auto. Sold
                      1988 e30 Cabriolet, 2.5L/5 Speed. Going for retro modern convenience driver.
                      • rnw
                        • Jun 2011
                        • 21
                        #6656
                        HI jay,
                        my wheels specification
                        - 17x8.5 et.13 flat
                        i want to use on 520i e34 with eibach sportkit.
                        please info what tire size, should i use.
                        i prefer staggered style.
                        thank you.
                        • Mystikal
                          • 9602
                          #6657
                          Should fit with the fender roll. I'd still suggest 195/55 though.
                          • Mystikal
                            • 9602
                            #6658
                            Doesn't fit. You need extreme stretch to fit those wheels with adapters.
                            • Mystikal
                              • 9602
                              #6659
                              Thanks
                              Step 1 would be to look to see what's rubbing. Can't create a solution without knowing the problem.
                              • Mystikal
                                • 9602
                                #6660
                                Thanks!
                                - Dan
                                Yes, 195/60 is the common second choice to actually find good tires. The Falken ZE-912 is good in the wet and comes in the stock size.
