This is a sticky topic.
  • Edirtyy808
    • Apr 2012
    • 297
    #7336
    i wanna just know the most backspacing for front and back with a 17inch rim?? i got a late model, on coilovers(joms) but switching to better ones.
    • mohamed...
      • Oct 2012
      • 577
      #7337
      Originally posted by Mystikal
      215/40 is the limit all around with either setup. Maybe 235/40 rear only if it's an early car.
      Is that because if fender clearance? Or offset?
      E30 M30 B35 Swap Mounts!
      http://store.garagistic.com/ocart/e3...=5475809a87e04
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #7338
        Both, by nature. I guess to answer another way yes, of course E30s can fit larger that 215/40 under their fenders.
        • mohamed...
          • Oct 2012
          • 577
          #7339
          How can I make that happen?
          • Ray Smoodiver
            • Jun 2004
            • 8809
            #7340
            17x8.5 ET13 all round
            Will be on H&R race/Billy Sports / E30 M3 gear.
            Thinking 205/40/17 and a fender roll f/r should see me right?
            • golde30
              • 11464
              #7341
              215/40 will fit with a good fender roll, have to run a 5mm spacer in front for that wheel. I have 2 sets of those same wheels.
              Going onto early or late rear fender arch? With that same suspension setup I am getting some rubbing on the rear with that tire size and late model rear archs. Dont want to go down in tire size, so looking to go with coilovers and stiffer springs to prevent rubbing on throttle and through hard turns.
              IG: @Baye30
              • Ray Smoodiver
                • Jun 2004
                • 8809
                #7342
                Late model arches. I'm running the 8.5 ET17 rear on a 215/40 right now (see sig) and it rubs slightly.
                That the same suspension setup in your sig?
                • Mystikal
                  • 9602
                  #7343
                  Higher net offset wheels. +25 is ideal for 235/40s.
                  • Mystikal
                    • 9602
                    #7344
                    Yup, 205/40 for a late model on E30 M3 hubs with those wheels.
                    • keefy6
                      • May 2011
                      • 991
                      #7345
                      Mystikal, I found a unique set of 15s, here are the dimensions rqst help again;
                      15X9.5
                      4x100
                      there is an option for offset, which is best 15 or 25? I'm thinking 15?
                      And which tire would be best?
                      Spacers needed?
                      My old Style 5 Thread / My Swap
                      1991 318IS :bow: 2.5L S14 Swap/BC Coilover suspension/Some new (old) wheels/
                      IS Skirt-Lip/RG Splitter/M-Technic I Spoiler/Dogleg/3.46 Diff/Euro H4 headlights etc.
                      1998 528I (Sold) // 2003 540I ///M Sport
                      • Mystikal
                        • 9602
                        #7346
                        15X9.5
                        4x100
                        Spacers needed?
                        15, and you'll likely need 10-12mm spacers for the fronts to clear the struts. 205/50 tires.
                        • golde30
                          • 11464
                          #7347
                          Yes same setup. But in the Sig I have 235/40/17 on msystems. I had to tweak the h&r race setup to make it sit that way, PM me for details.
                          IG: @Baye30
                          • mohamed...
                            • Oct 2012
                            • 577
                            #7348
                            We'll I already have 2 sets of wheels with offsets lower than that. Can I make it work with the fender roller?
                            • keefy6
                              • May 2011
                              • 991
                              #7349
                              great, thanks again this size tire isn't too tall or too thin right? looking to fill the wheel well.
                              • Mystikal
                                • 9602
                                #7350
                                No
