	This is a sticky topic.
 I'm guessing this is pretty standard fit, but i'm looking at
 15x8 +25 with 205/50 (i'm currently on Style 10s, 15x7 +24)
 Fender rolling needed? I'm on Billy Sports with H&R race. Offset FCAB for some camber, that's it. Otherwise unremarkable. It's mainly a DD with some canyon runs and an occasional auto-x.Comment
 I'm not Mystikal, but from the looks of those specs you will be fine.FEEDBACK:
 http://www.r3vlimited.com/board/showthread.php?t=316212
 BMWCCA #398608
 IG @yagayo38
 "The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
 Can porsche fitment 5x130 wheels be drilled and filled to fit a 4x100 car? I was told it was t possible by rotiform, just wanted to check here as well.Originally posted by IRON-EYeah, you're definitely a vw Comment
 I'd like to know whats my limit before having to pull the fenders, mind you the car will be
 on air suspension.
 I was thinking and please do advice, 16x8.5 Fronts 16x9.5 Rears I am not too sure of what offset the wheels should be given the sizes. Also tire sizes, I know a lot of you here aren't into this form of fitment but any advice would be greatly appreciated.Comment
 Rodrigo, what're the offsets on the wheels and are you going with a slim bag or double bellow?Originally posted by IRON-EYeah, you're definitely a vw Comment
 I'm doing Airlift Performance series struts with double bellows, I don't know what offsets to do because I am getting a set of 3pc rotiforms built for the car and I haven't ordered yet because I don't know what offset to run before I have to do major body work. I really don't want too.Comment
 3mm front spacers, otherwise good to go.I'm guessing this is pretty standard fit, but i'm looking at
 Fronts will likely to get down to +7 or so to clear the front perches. If you keep the rears at +15, 205/45 front 215/45 rear is possible.Comment
 +5 all around. 195/45 front 205/45 rear.I'd like to know whats my limit before having to pull the fenders, mind you the car will be
 on air suspension.
 If I were to get Salad shooters and 5x120 adapters, would I need longer wheel bolts or would the stock ones work? I have extra wheel bolts laying around.
 Also the tires on the wheels I'm looking at are 255/50 would I need to roll my fenders? And anything else that goes into installing these wheels I'm not aware of?Last edited by anabolice30; 03-25-2014, 06:45 PM.Comment
 Not nearly enough info for me here.If I were to get Salad shooters and 5x120 adapters, would I need longer wheel bolts or would the stock ones work? I have extra wheel bolts laying around.
 Also the tires on the wheels I'm looking at are 255/50 would I need to roll my fenders? And anything else that goes into installing these wheels I'm not aware of?Comment
 Thanks mystikal, for sharing your wisdom, sorry if I leave any important info out, I'm new to this. I'm looking to get staggered borbet type a's (16x7.5 et15 in the front/16x9 et20 rears) for my 91 vert. I'm about to go through the suspension, and will probably go with billy sports and h&r springs for about a 1 1/4 inch drop. My question is what tires and spacers should I run to fill everything out nicely? (I don't mind rolling my fenders a little, and I am not a fan of stretch)Comment
 Offset: 40mm
 Backspacing: 6.26"
 Bolt Pattern: 5-120
 on e36 m3 5 lug, late model, bavauto springs, rolled fenders. possible with 215/40 S-drive?
 will be running whatever camber I can run with shims up frontLast edited by Julien; 03-28-2014, 09:31 AM.Comment
