Will distort 1/4panel. You can lightly tap on it, but it is rite up against the 1/4.
	This is a sticky topic.
Ah, gotcha. If it makes you feel better the 10" front rims I currently run on my Z3M touch both front coilover locking rings near lock. It just polishes off the edge, no biggie.Comment
No, there will be a gap unless the car is lowered more.Originally Posted by aworthybrother
Hi,
Can i run 20mm adapter spacer with no rubbing? My fenders are not rolled.
(Ronal LS 16x7.5 5x120 et35)
Yes, but only with 205/45 tires.
Will 205/45 x 16 tires fill the fender gap on an early vert sitting on m3 springs? ThanksComment
Don't buy tires until you test fit them. Mahle's have very poor caliper clearance so check if you'll need spacers before you commit to a tire size - you may need to adjust it accordingly.Hello everybody! I've got a nice set of BBS Mahle's in the mail for me for my 1990 325. The specs are 15x7 et13.
I'm looking at tire-rack and I can get the Dunlop Direzza ZII in 195/55 or 205/50 but the only high performance tire I can find in 205/55 is the Yokohama S drive.
What do you guys recommend? Any input is greatly appreciated, thanks
ThanksComment
In my opinion, the offsets are way too low for use with E36/Z3 geometry. The wheels will be far outside of the fenders. The offsets are ideal for E30 M3 running gear, subtract 15-20mm (numerically add) of offset for these to work well.Thank you for the help in advance.
I have a set of 3 pcs wheels and these are my options. I can change the inner barrel (would the second option be a better choice?
GC coilovers and pretty low, fine with rolling ect.
Front: E36 m3 front 5 lug swap
Rear: 318ti
17x8.5 et13
17x10 et 19
Or
17x8 et 13
17x9 et 19Comment
Yes it will rub, the commonly chosen sizes for that wheel are 205/45 or 215/40. You will need 3-5mm spacers to clear the front struts, none in the rear.Comment
The only 4x100 OE wheels that will bolt up are from VWs. The Miata, Civic, Mini, etc. use a smaller centerbore than the E30 (57mm) and as such won't fit our cars without either custom machining or custom spacers.I have an 88 325ic that I'm looking to put snow tires on. Found a set of Mazda Miata stock steelies with tires on them that look interesting for the price, but, need to be sure the rims will fit my car. I think I've seen information somewhere indicating that rims from the Miata, and some VW cars will fit mine. Just want to be sure before I buy. They're from an early Miata based on pics I've seen of the car. The rims are four bolt 4X100's. I've attached a link to the sale posting.
Any information would be of real help.
Thanks!!Comment
I'm shocked you managed to get them to bolt up. Even with a 5mm it would touch the strut, 8mm is the minimum required to be safe. I'd suggest getting a 10-12mm hubcentric spacer (with lip) instead though, as getting a flat 8mm spacer to balance well is near impossible. I'd use that size spacer all around, on an '87 with 195s you should be fine.hi I have 16x9 klutch sl1 et20 on my 87 325e. they rubbing quite a bit on front caliper and strut, I've got 195/45/16 fitted at the moment. perhaps 5mm spacer for front and extended lug bolts? The rear is really tight with room would you suggest spacing it also?
cheers In advanceComment
I'm too lazy to convert to backspacing, but order +20 front and +15 rear. This is assuming you have normal and not super-long front GC springs (6" 160mm or shorter).Im in the process of ordering custom 18x8.5 in the front and 18x10.5 in the rear to fit something like 245 & 295 tires on them with fender flares. All in preparation for an engine swap. However, the company is asking me how much clearance I have in terms of backspacing with my ground control coilovers. With lowered cars, theres issues clearing the spring/adjustment collar. Could anyone lowered with GC coilovers tell me how much backspace theyre running or how much clearance they have?
Thanks in advance.
I run those same tire sizes/diameters on my Z, due to the 135i using the 245s as rears and P-cars running the 295s there is great selection. Nice choice.Comment
5mm front spacers and none are needed in the rear, though 5mm also fits. You can run 205/50 tires all around to get as much sidewall as possible under you. No rolling.Hey guys, so I want to fit some Varrstoen V1 4x100 16x8 +25 all around.
Going with Billy HD and probably H&R springs when I get them, as I have cut springs right now from previous owner lol. Thinking of that setup for daily driver, in Vancouver, BC but the roads are somewhat shitty.
Will I need spacers to mount them on? And has anyone else ran this setup?
Would I also need to roll my fenders? I'm hoping not to.
Thanks in advance!Comment
E30 M3 running gear, unfortunately. Adapters would place the wheels out too far, and E36/Z3 gear would have the same issue. If you find a non-4x100 set of wheels, check if the offset is above 30. Then you can buy a set of adapters and slap them on.Comment
They'll sit fairly flush with adapters, but you would be limited to 195/50 tires. With a redrill up to 225/45 is possible, if you're into that sort of thing.Comment
Need to get down to +13 or so to clear a 17x9 with big rubber up front, so a 5mm spacer may be necessary there. The rear should fit fine. Obviously front camber needs to be aggressive.Late model, Ge coils, linear springs, front perch cut, 17x9 et30 square setup, this 5 lug kit http://www.r3vlimited.com/board/showthread.php?t=330653 , which adds 12mm on the front and rear stays on e30 fitment. 245/40 tires.
Possible?Comment
