This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #7906
    Originally posted by TrentOSU
    So..I have a flawless, essentially brand new set of style 7's..they are 15's but I am not sure of the offset and they have a 7.5 width. Would these work for my 325is? I am aware that they are 5 lug.
    I'm not going to google the wheel specs for you, but when you do, let me know!
    • Bullhead
      • Sep 2014
      • 532
      #7907
      Originally posted by Mystikal
      No. I always recommend coilovers on E30s, especially BCs.
      Can a 245/40 17 fit? sorry for the questions Mystikal I am just looking at my options. And what's the widest you can go in the rear with a full roll on the 17's?
      sigpic87 325E The Honey Badger
      • g.ruff561
        • 1261
        #7908
        16x7.5, et 15. What tire size do you recommend with no rub or mods lock to lock. Front only on h and r sports? Wheels are Schmidt Modernlines. Thank you sir.
        • ScottCantStop
          • Aug 2014
          • 23
          #7909
          Year, Model, Suspension, All Relevant Wheel Data (Diameter, Width, Offset, Bolt Pattern, etc)
          1989 325i, Ground Control Stage 2+? coils, 500/600. Looking to run a 17x8 Apex wheel.
          What's the widest tire I can run, and what offset would I want the wheels to be to achieve that? Trying not to stick out the sides of the car, planned on rolling the fenders.. Hopefully this isnt too vague of a question
          Thanks!
          S
          • Reignity
            • Jul 2014
            • 18
            #7910
            I'm getting real confused. I'm looking at 15x7s on 205/55 tyres, but what offsets can I have? Some seem to be running as little as +15, but then I've seen up to +38. I want to keep the rolling circumference as close to stock as possible to avoid issues with fitment, just unsure on offsets.
            Also, there's a good chance this has been answered, but there's 500 pages. Thanks in advance.
            • blk90e30
              • Sep 2012
              • 91
              #7911
              Looking at a set of wheels, I know its a long shot and i will need spacers but im having trouble figuring out what size to go with. 90 325is St lowering springs and billys. 215/45/16 dunlop direzza dz101 tires 16x7 et 40.
              • Randy2400
                • Apr 2014
                • 55
                #7912
                I have et 25 apex arc 8 wheels 17x8 with 5mm spacers and bc racing coilovers what's the largest tire size I can run in the rear? 255/40/17 or 245/40/17?
                • jrockbk
                  • Jun 2013
                  • 369
                  #7913
                  I'm on coilovers, currently on 225/40/17 all around but tires are not made anymore thinking of going 245/35/17 in rear. Wheels are 17x7.5 et28
                  Rear wheel with no spacer and my fenders are rolled and 750lb rear springs. Think I can do 245/35 in rear if I raise it a little?
                  • Mystikal
                    • 9602
                    #7914
                    In the rear without spacers, yes. Rolling necessary as well as coilovers with relatively high rates.
                    • Mystikal
                      • 9602
                      #7915
                      205/45s are perfect.
                      • Mystikal
                        • 9602
                        #7916
                        Thanks!
                        S
                        They were only made in the ideal offset (which I gave to them, heh) of +25. 235/40 is what they were designed for.
                        • Mystikal
                          • 9602
                          #7917
                          Yes, down to about +15 should work. No higher than +27. The lower within this range, the better they will look.
                          • Mystikal
                            • 9602
                            #7918
                            15mm front 20mm rear would look nice. Can also do either of those sizes all around and it will work fine.
                            • Mystikal
                              • 9602
                              #7919
                              With spacers, only 215/40. Without spacers, 235/40.
                              • Mystikal
                                • 9602
                                #7920
                                Too wide and short of a tire for the wheel. 235/40 would just fit and work well.
