This is a sticky topic.
  • haaken675
    • Sep 2016
    • 601
    #9256
    with 17x8.25 et25 wheels would 215/45's work? Would I need to roll my fenders just to get them to fit? If so, what would be a more preferable size (if there is one)?
    Thanks
    • Staszek
      • 2533
      #9257
      Ok I ditched all my other plans and I need the following info.
      1990 325is, it will be on Koni Adjustables with H&R Sport springs. I have IE Wilwood BBK the 16" slim versions.
      I want to run 16x8 all around with 225/45R16, although if its better I could make the barrels 7.5
      I am currently having custom BBS RS's made so I can do any offset I need. I was thinking ET22 would clear the rears so I would not have to roll.
      If that wont work is there an ET in the rear that will work so I dont have to roll?
      • MogSpeedE30
        • Apr 2014
        • 9
        #9258
        Need some advice on what tires, here is the current setup
        Wheels: 16x7.5 ET30 Borbet Type C
        Car: 1987 325i Sedan
        Modifications: Front Fenders Rolled, Rear Quarters still stock, Bilstein Sports, H&R Super Sport Springs
        Current Tires: 205/55R16 Front, 225/50R16 Rear (long story on the stagger)
        Looking at doing 205/50R16 Front and 225/50R16 rear, wondering what spacers i would need and if i would have to do rear quarter work (would love to do 225/50 all around)
        1987 325i - Bilstein Sports - H&R Super Sports - Turner Mounts - 16x7.5 Borbet Type C's - 205/55 Front, 225/50 Rear Goodyear Eagle GT - Condor SSK - Badwella DSSR - Shift/Brake Boots by BWeiss Leather (aka F34R) - 20W50 Brad Penn #1 Green Oil keeping it lubedsigpic
        • Staszek
          • 2533
          #9259
          Can anyone confirm if ET22 will work? I know that this thread can slow down sometimes but I am on a time crunch with my order.
          • gammapowered
            • Aug 2016
            • 8
            #9260
            17's on 90 sedan E30
            Hello, Im looking at XXR 527 17's. I see that there are a few options. I like the idea of the staggered setup. 8.25 front et 25, and the 9.75 rear et25. What is the right size tires, i prefer max width. Also what spacers would i need. I really want wider tires for the performance.
            Thank you,
            • varg
              • May 2014
              • 3319
              #9261
              So what would be the perfect offset on a 16x8 wheel front and rear to fit 225/45R16 tires
              I can roll the rear but is there an offset that would fit my car perfectly. 1990 325is.
              When I say perfectly I am not a fan of the poke I would like it flush, I will be running H&R sports.
              ET20 works. I run 16x8s with 225/45/16 Star Specs
              IG @turbovarg
              '91 318is, M20 turbo
              • Flexx
                • Sep 2016
                • 24
                #9262
                16x8 et25
                So I just received a set of 16x8 et25 ( but ordered 16x8 et20) and before I send them back I was wondering what size tires I should run and will they work without rubbing? The car will be lowered 2"-3" max drop and I was looking at using 205/50/16 tires previously.
                Will I need to do and rolling of the fenders or use spacers?
                I have a 89 e30 325is.
                Thanks ahead of time.
                • CrazyIvan
                  • Apr 2013
                  • 33
                  #9263
                  Looking at a staggered set with the following specs:
                  15x8 ET8, 15x9 ET-6
                  I'm at stock height, and might go for an enthusiast drop (verse stancer).
                  How will this be for fitment, and will I need spacers?
                  • Staszek
                    • 2533
                    #9264
                    Thanks just ordered the star specs
                    • Das Delfin
                      • Sep 2014
                      • 2293
                      #9265
                      Hi Jay, got a question for ya
                      I want to go 16x9 et15 in the rear of my cabrio on H&R sport springs (for now). I want stock diameter (or slightly greater; my car has a 4.10 rear) and not too much of a stretch.
                      How can I fit 245/45? I'm also looking at 225/50 or 225/45. I can roll my fenders but not sure I want to pull them just yet. Thanks!
                      • Staszek
                        • 2533
                        #9266
                        245/45 wont fit on a 16x9 et 15 it will rub. 225/45 could not sure about that offset. 225/50 is too tall.
                        • Das Delfin
                          • Sep 2014
                          • 2293
                          #9267
                          I was doing more reading and it looks like a 245 is way too wide! However a 225/50 tire is 632mm tall compared to a stock 195/65 being 610mm. Which means fender gap is reduced by 11mm, less than half an inch. I'm on H&R sports, not low really. I don't see why the tire being 11mm closer to the fender would matter. I mean, lowering springs will produce more of a reduction in clearance. Is there another factor I should be thinking about?
                          Trying to do as much of an education guess as possible because I want to keep this setup for a while.
                          • kid8
                            • Jul 2013
                            • 312
                            #9268
                            16x7.5 et20. Car is a late model with h&r sports. Could a 205/50/16 fit without rolling? It has a 1.5mm space in the front for a brake kit.
                            • mdlax30
                              • May 2013
                              • 44
                              #9269
                              Ahoy!
                              I have a 91' 318is, stock ride height. I was looking to put on Varrstoen DS12's in 15x8 et25. What tire size would work without fender modification or looking completely silly (I don't mind a slight stretch)? I was thinking tire sizes 205/50/15, 195/50/15 or 205/55/15?
                              '04 E46 M3 Vert
                              '91 E30 318IS
                              • KYdirte30
                                • Feb 2017
                                • 21
                                #9270
                                15x8.5 et17 tire selection
                                What's up guys. I'm a noob in the wheel/tire game so looking for knowledge. Gonna be running 15x8.5 wheel with et17. Wondering what a good tire size would be to run without rubbing (don't wanna have to roll the fenders if I don't have to). My 325is couple is lowered a little on GC coils. Also wondering if I'm gonna have to run spacers.
