This is a sticky topic.
    • 34827
    #9646
    Originally posted by turbski
    I just wish there were more options for the 14". I have been debating on grabbing a set of the toyo proxes r888 in 205 50 14. Anyone run these on a street car?
    I haven't run them on 14", but they've been my "street" tires on the E30 since like 2009.
    They are loud though, and stiff. Don't expect 50,000 miles either.
    • turbski
      • Jul 2018
      • 329
      #9647
      do they hook up ok? the noise I can live with as its 3in from turbo back with vibrant resonator and muffler. Im running a cheap 195 65 14 right now and if im not paying attention 2nd and 3rd gear are useless.
      • djanalog
        • Aug 2017
        • 31
        #9648
        Very noobie question here. I have an '87 coupe with 14' bottle caps. Tire size is 215/70 R14. I am looking to get an e30 sedan, also with 14' bottle caps. Those tires are 195/65 R14. Are these wheel/tire sets interchangeable? Thank you.
        • turbski
          • Jul 2018
          • 329
          #9649
          Yes. If you Google tire size calculator there are a few good ones that will give you max and min tire sizes for a given wheel size.
          those will fit
          • djanalog
            • Aug 2017
            • 31
            #9650
            Thank you very much for the help!
            • mabimmer
              • Aug 2018
              • 41
              #9651
              Is anyone else here running the new ground control full coil over kit and if so what wheels and tires are you running? I just installed the kit and took it to the track and it was awesome but I am still running on 16" redrilled wheels and conti street tires. Want to go to the widest tire I can am open to 15, 16 or 17's. I do like the Apex wheels but I know they will be heavier than say a slipstream. Yes I have tried searching but can't find my exact combo.
              Free shipping to Europe on all Rota Wheels : Rota Slipstream 15x8" 4x100 ET20, Satin Black ! Awesome design and perfect finish for your car.
              looking these
              or these
              Either with a Toyo R888R in as wide as I can go. Probably 225 square right?
              The guy I bought the car from says the fenders are rolled front and back but I have no idea how much.
              Brilliantrot 1991 325-1995 BMW S50 Engine S50 intake-headers Borla Pro XS- 318is Radiator Spal 16” pusher fan Cone filter Tuned by RK- Bilstein Sport dampers with IE springs -Z3 steering rack- 16” style 5 from E32 Wilwood 4 piston Dynapro calipers -EBC pads Volkswagen Corrado rotors stainless steel lines-E32 M5 master cylinder, 325iX brake booster, 2002ti remote reservoir-1996 325i driveshaft Z3 3.15 Torsen LSD Z3 1.8 shifter IS lip and spoiler Antenna deleted Euro Grilles
              • Dawskip
                • Feb 2018
                • 242
                #9652
                Is it possible to get e34 basketweaves to fit on a e30?
                • Staszek
                  • 2533
                  #9653
                  With an 18mm 4x100 to 5x120 adapters they will be at an offset of +2, you can make it work with fender work and narrow tires but it will be really tight. They wont fit as is. The will fit pretty perfect if you do a fill and drill.
                  • dcw242
                    • Jul 2017
                    • 15
                    #9654
                    Been doing a bunch of reading and think I've come to a decision, just need some verification/confirmation before I pull the trigger:
                    Early Model E30
                    Fortune Auto Coilovers
                    IRE 295 BBK
                    For consideration:
                    15x8.5 +25 (5-10mm spacer all around (Exact size TBD))
                    Will 225/45/15 fit or do I need 205/50/15?
                    Rear Fenders are pulled and front fenders are rolled. I'm not all too concerned about aesthetics/stance. Just trying to get as much grip as possible for future plans (Aiming for 450+ whp).
                    My concern with the 205 is that I'm essentially losing a good bit of surface contact. The 225/45 should be about the same height as the 205/50 but the shoulder will be an inch wider. I don't mind lifting the car .5-1" to clear the wider shoulder if it means an 2" of additional contact area.
                    • Rubenlopez101
                      • Mar 2016
                      • 18
                      #9655
                      Can someone help me on a size 16X9 25 offset. Car is lowered on eiabach prokit and konis. Thanks in advanced!
                      • flamesone
                        • Feb 2006
                        • 114
                        #9656
                        Car: 1988 325i convertible
                        Suspension: KW V3 coilovers
                        Wheel: BBS RS Reps 17x8.5 et15 all corners
                        Tire: 215/40/17 or possibly 225/40/17
                        Can someone confirm this will work without any rubbing? Do I need spacers??
                        TJ - Alpine 88' 325IC
                        • Bme3092
                          • Nov 2015
                          • 41
                          #9657
                          Need some tire help please.
                          Bbs rs 16x7.5 et19 front and 16x8.5 et20 rear.
                          I bought 205/50s and 225/45 and they are huge and needs lots of rolling. Car is also dropped on H&R sports.
                          Looking to get get new tires. Any thoughts??
                          • Bme3092
                            • Nov 2015
                            • 41
                            #9658
                            Here is the setup.
                            205/50 front 16x7.5 et 19
                            225/45 rear 16x8.5 et 20
                            • Slybeanx
                              • Dec 2018
                              • 518
                              #9659
                              Car: 1990 325i coupe
                              Suspension: Jom coils
                              Wheel: JNC15x8 et20 4x100
                              Tire: 225/50/15 or 205/50/15
                              I'm going for fitment, I'd like it tucked if possible would this work?
                              85% of the time i have no idea what I'm doing
                              • onlyindef
                                • Dec 2017
                                • 42
                                #9660
                                Year: 92
                                Model: vert
                                Suspension: airlift e36 front struts with e30 camber plates, rear is e30 airlift with z4 hubs.
                                wheel stats: konig ultraforms 17x8 5x120 et35
                                Tire Size: I want meat, minimum 225/40, 235 preferably, and open to 245 and up.
                                other info: willing to roll my fenders, like a fat chick on top of a hill.
                                just need to know what size spacers I need?
