This is a sticky topic.
  • Mystikal
    Wheel Fitment Expert
    • 9602
    #1276
    Originally posted by gmvt
    Bought a set of Rota Slpstreams today . Going on a restored 325 vert 86.
    After reading all your posts I felt this will work without spacers. Now I need to order tires.
    I dont want to roll fenders. Brand new paint in inner fenders. 215/225 40/45/50 ??????
    Any help most appreciated.
    Bob
    Ludlow, Vt
    There are lots of choices that will work without rubbing:
    205/45/16
    205/50/16
    215/40/16
    215/45/16
    Choose whatever your favourite tire is available in. The 205/50/16 is the only one as tall as a stock tire, which some prefer for speedometer/odometer accuracy, load rating, and wheel well filling reasons. The others are all slightly shorter, with the 215/40/16 being the smallest of the bunch.
    • evil_twin
      • Nov 2007
      • 2965
      #1277
      Would a 17x7 wheel with a 40mm offset work for our cars?
      Paypal: vdang5@gmail.com
      Delta Auto Care
      2875-C Towerview Road
      Herndon, VA
      703.435.1375
      My Feedback Thread: Evil_Twin
      • StereoInstaller1
        GAS
        • 22679
        #1278
        Originally posted by Mystikal
        You can get reasonably close with a slide ruler or something like that. Just measure the distance from the hub face to the rear edge of the wheel and use the wheel width to calculate offset. Keep in mind if you have to manually measure wheel width (as in lip to lip) it's always 0.5-1" wider than the actual width we use in wheel talk.
        So, basically, it is the distance from the centerline of the wheel to the hub? My wheels do not have any markings at all...
        I put a set of Racing Dynamics 16X7.5 on my car, they are ET25, rocking 225/45/16 tires, forget which ones. They definitely are not nearly as flush as my 17's. I think my 17's might be ET20, maybe ET15, but as soon as I pull the tires off I will measure.
        So now I want to convert to studs. Any handy suggestions on how to properly measure to make sure I have proper thread depth both on the lug nuts and the hub?
        I have to use gay-ass "tuner" lug nuts, but I am gonna use the style that is driven from the outside and are fully threaded...the other style looks like it might be hard to get perfect...and I am gonna use 10mm spacers in the rear.
        Thanks so much for the help!
        Luke
        Closing SOON!
        Thanks for 10 years of fun!
        • Mystikal
          • 9602
          #1279
          It'll bolt on, but it will be like a foot inside the fenders (not really, but it looks stupid).
          • Mystikal
            • 9602
            #1280
            Luke
            It's the difference between the wheel's centerline and the hub. So an ET20 wheel has its hub face 20mm outboard of the center of the wheel.
            For the studs, you need at least 12mm of engagement. A standard 45mm kit or whatever it is is more than enough for use without spacers.
            • evil_twin
              • Nov 2007
              • 2965
              #1281
              LoL. Thanks again. I guess I will stick with a 15x8 et 0. I just would have had a sick deal on a pair of 17x7 wheels.
              Thanks
              Delta Auto Care
              Herndon, VA
              703.435.1375
              • bimma360
                • 1940
                #1282
                17x8 et20...
                What are my options for tires... i'd LIKE to run 225's up front and 235's in the rear. I'm willing to roll the fenders a bit if i have to.
                Dave
                E30 Dinan Turbo
                • Mystikal
                  • 9602
                  #1283
                  Thanks
                  I think 17x7 ET40 looks less retarded than 15x8 ET0. :p
                  • Mystikal
                    • 9602
                    #1284
                    Originally posted by bimma360
                    17x8 et20...
                    Dave
                    First, are you 5-lug? If so, E30 M3?
                    • z31maniac
                      • 17566
                      #1285
                      You can do 8mm in the back with just a small fender roll on the 17x8's. The front can handle 3-5mm to problem.
                      Obviously the wider the wheel the better out of that range for the 15s. Something like the Team Dynamics at 15x7 ET25 makes the 225 easy to fit. The wider the wheel gets, the wider the tire gets pulled, the less room for error you have.
                      Since the fronts are rolled (and ever so slightly pulled) I will go 5mm in the front.
                      Since the backs are rolled pretty good as well, can I go 10mm?
                      I'm planning on lowering the car on the coils even more, so the back will get some help with camber. Is 15mm spacer in the back possible? Or would that take running a 205/40?
                      www.gutenparts.com
                      • Mystikal
                        • 9602
                        #1286
                        Even an 8mm isn't the best option, as the hub will probably be completely covered. 10mm is possible with a flat lip though. 15mm...not so much.
                        • bimmer_E30
                          • 5001
                          #1287
                          would 245/45/16 works with sportmax's ???? 501 16X8....
                          Originally posted by e30e
                          • Mystikal
                            • 9602
                            #1288
                            Sure. With huge flares on the car.
                            Anything bigger than a 215/45 on those wheels is tough.
                            • bimmer_E30
                              • 5001
                              #1289
                              so if i went with 215/45 with the 501 would the rear wheels rub???
                              • Mystikal
                                • 9602
                                #1290
                                You'd have to roll the rear fender lips. 205/45 is what you want if you want to avoid any extra work.
