Are you using any spacers? And since its not a BMW wheel, you might have a different seat than stock. Unlikely, but possible.
who has studs?
By design they are and should be difficult to remove. The Loctite 262 (assuming you used some from the included tube - you should have if you followed the instructions) is doing its job.I am going to have to call vorshlag up about removing the studs, its a lot more difficult that the instruction make it sound. I feel like I am going to strip the stud if I hold one lug stationary and try and turn the other. Maybe it wont but I want to be sure.
I had to replace one of my strut housings and I am going to have to remove the studs again when I do the wheel bearings this summer.
You didn't say which studs you have, but if you have our 60, 75 or 90mm studs, which have the recessed Allen head drive, you can't use that to remove them. The torque necessary to break loose the Loctite is more than the Allen drive can take, and we state as much in our instructions.
Its a common removal mistake noted on more than one stud sellers website (Turner's site says as much also). We show what "double nutting" is in the instructions as well as our "Wheel Stud Helpful Hints" instructional picture gallery. Have a buddy step on the brakes to keep the rotor from turning.4. REMOVAL HINTS: The allen
hex in the studs are not strong
enough to remove when Loctite is
used. Follow the double nut
procedure when removing studs.
Do not use an allen wrench.
And remember - wheel studs and lug nuts are just as much of a wear item as the factory "wheel bolts". If they are over 2-3 years old, just replace the studs when you go to install the new hubs (this is what race teams use for replacement intervals, but for a non-competition car they can and should last longer). If you feel like you might strip a stud, or don't want the hassle of removal (it is a pain), just buy some new ones beforehand. We sell them 1 at a time if you need that and they don't cost a lot.
Thanks,Terry Fair - www.vorshlag.com
Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(Comment
Yeah I got your message you left on my phone, I put the nuts facing each other just like shown in the instructions. But when I turn the inboard nut and stud doesnt spin, I am afraid that I am stripping the stud or nut. But I havent given the wheel bearing / stud any heat yet so I am off to that.By design they are and should be difficult to remove. The Loctite 262 (assuming you used some from the included tube - you should have if you followed the instructions) is doing its job.
Thanks,
This strut housing is off the car, and the housing is disassembled.
Thanks for advice Terry,
TravisComment
Travis,Yeah I got your message you left on my phone, I put the nuts facing each other just like shown in the instructions. But when I turn the inboard nut and stud doesnt spin, I am afraid that I am stripping the stud or nut. But I havent given the wheel bearing / stud any heat yet so I am off to that.
Travis
If the housing and hub are off the car is going to be more difficult, as you don't the the added leverage of the chassis and the brakes to hold the hub in place... just make sure to put the housing in a vise and using 2 installed studs and a prybar between them for leverage, have a friend secure the hub to keep it from rotating. Once you tighten the 2 nuts to each other (as shown) and the shaft using two 17mm wrenches, you just have to put all the leverage you can on the inboard nut with one wrench... it should pull the stud out eventually. Again, some heat to break loose the loctite might help if its stubborn. Doing these on the car can be a tick easier unless you have a very solid, table mounted vice and some help.
New hubs are a bit pricey, but they are a wear item, so don't kill yourself trying to save a $140 front hub and some suds. Most road race teams replace BMW hubs (and studs and lug nuts) every 1-2 seasons, depending on the use. Endurance cars have even shorter intervals. The joys of racing. ;)Terry Fair - www.vorshlag.com
Damn i hate Ebay. would anyone trust these? http://cgi.ebay.com/ebaymotors/LONG-...Q5fCarQ5fParts
my reccomendation, unless it's for street use ONLY do not buy anything but the black hardened bullet nosed style. the chrome ones are made of a cheap material and can't handle the stress of track use.Comment
Hey thanks for the input nado. Does it really matter what color the studs are? have you had issues with the none coated ones?
My car sees coastal spirited drives every weekend and an occasional auto-x and I'm looking to buy these http://www.velocitymotorcars.com/stu...-50mm-oal.html they are rated at the same strength as the Vorshlags, 150,000 psi.
Does anybody know what size stud I would need for 15x7 et25 with a 3mm spacer. I am getting d-force wheels and want a 3mm spacer to clear a Massive brake kit. Do you recommend a particular brand?Comment
