What oil weight is everyone using?
  • GillesBigCowboy
    • 507
    #121
    20w50 castrol
    87 4dr specE30: Bitsy (lurking above), 89 4dr 325i blau, 91 318is brillrot, 90 325ivertbronzit
    • craiggroves91
      • Oct 2009
      • 3024
      #122
      I always ran GTX 20w50 high mileage like various others have stated
      1989 BMW 325i SOLD
      1998 BMW Estoril Blue e36 M3/4/5 SOLD
      1987 BMW 325 (The Piece) SOLD
      1991 BMW 318is S52 swap (The Beast) Now Driving Project Thread: http://www.r3vlimited.com/board/showthread.php?t=234207
      • ethrtyiS
        • 8147
        #123
        m20 - 20/50 castrol gtx high mileage.
        s50 - 20/50 castrol gtx high mileage.
        no leaks or burns in either engine.
        「'89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5 」
        「my feedback thread」
        • stamar
          • Apr 2011
          • 1362
          #124
          I use napa 15-50 full synthetic which is made by valvoline. I dont have the data of valvoline zddp content but Id be interested.
          when I had 10-30 in there it leaked constantly. at least a quart every 1000 miles...
          I only went about 2000 miles before changing it again to 15/50, and there is basically almost no leaking since.
          I have only changed the oil 3 times though.
          It has never looked dirty to be honest at any time ive owned it. Its always had full synthetic. Its on a 7500 mile schedule.
          I use napa gold filters which are made usually by wix, but I used one made by gard too.
          po used mobil 1 and fram tough guards ( which is still terrible but better than the orange frams)
          • scottinAZ
            • Dec 2009
            • 1312
            #125
            15w-40 rotella or Delo 400. used in both the old M20 and the new M50. burns about a quart in 3k miles.
            I saved 15% on my Bimmer parts by switching to ...
            • stamar
              • Apr 2011
              • 1362
              #126
              its bad but not emergency bad.
              In this case it wasnt long term. It causes a lot of carbon in the combustion chamber. I feel certain i cleaned it out with sea foam.
              I had never had a car burn that much oil before, and I used to own air cooled vws which do burn about 1 quart per 2000 miles even when new.
              switched to thicker oil and it ended. I dont have any data to give on how much its burning now, almost nothing believe it or not.
              • Kershaw
                • 11822
                #127
                Originally posted by Vivek
                Isn't it really bad for your engine to burn oil because of all the carbon deposits it creates on the head/pistons/valves?
                those carbon deposits are the only reason your 250k mile motor still has compression.
                AWD > RWD
                • JinormusJ
                  • 6887
                  #128
                  10w40 Full Synthetic Mobile 1
                  I think my PO was using 5w50, because the oil was really thin and looked as good as it went it. Amazing there were/still are no leaks... I will drop a weight next oil change
                  Thank you God for sending me a PO that caring enough to replace their oil pan gaskets, filter gasket, and rear main seal before selling their car for $800 to a noob. Amen :)
                  • stamar
                    • Apr 2011
                    • 1362
                    #129
                    theres no 5w50 oil
                    theres 5 30 and 5 20....
                    apart from being the wrong grade, its also the stuff without the zddp...
                    ( but I did take note that theres a filter gasket that leaks and Im about to look into it for a freeway leak on my car so thanks)
                    • imwhyteyo
                      • 1165
                      #130
                      5w - 40 Amsoil synthetic european blend
                      built m50nv turbo. so smooth.
                      • tbruz
                        • 428
                        #131
                        15/50 full syn mobil1, with a bosch filter
                        • Thizzelle
                          • 4422
                          #132
                          m20 - 20w/50 castrol gtx high mileage.
                          m42 - 20w/50 castrol gtx high mileage.
                          s14 - half 20w/50 castrol gtx high mileage & half 15w/50 full syn mobil1
                          "I wanna see da boat movie"
                          "I got a tree on my house"
                          • 85e325
                            • May 2011
                            • 551
                            #133
                            15w50 mobil one FRAM Xtra gaurd filter 271,000 mile eta
                            Justin Angelli
                            1985 325e Gazellenbiege
                            • imsotyerred
                              • Oct 2005
                              • 2529
                              #134
                              15w50 Mobil 1 syn after the first 2000mi on, I think, RotellaT or some other ZDDP enhanced stuff
                              built M20
                              BRUTE
                              • stamar
                                • Apr 2011
                                • 1362
                                #135
                                this is as off topic as it gets... but I know someone knows the answer here.
                                Is a toyota 20r a tappet engine?
                                who ever answers first is the winner of biggest car nerd.
