Is there a DIY for manual window conversion.
  • woodisgood
    • 1087
    I searched. I want to convert from power to manual if thread title was unclear.
  • lolcantturn
    • 4588
    Why?
    Originally posted by TSI
    OEM+
    • Jean
      • 18228
      Because Race Car
      • lolcantturn
        • 4588
        full race as FUCKKKKKKKK
        OEM+
        • Jean
          • 18228
          OP - it's pretty straight forward but you'll need to make sure you have matching glass... there were at least two styles of front door glass and they mount differently.
          • woodisgood
            • 1087
            I just need the handles/remove motors or do I need to change mechanism.
            • Jean
              • 18228
              you need to give us more info, how late/early is the car. usually you swap the mechanisms, and if it's a late model you'll need to swap the whole thing with glass and all.
              • woodisgood
                • 1087
                Sorry, 1985 325e, European spec. Canadian car I think. No A/C or power steering from factory. I want to make this car as close to a motor and a chassis as possible while leaving it intact.
                • Jean
                  • 18228
                  Ok, so it should have the early style glass and actuators (cable style). Take door panels off and confirm.
                    • 34844
                    the motors only weigh maybe 1-2lb each, I can't see this being worth the cost/headache...
                    • KenC
                      King of Kegstands
                      • 14396
                      From what I understand, the manual mechanisms weigh more when fully converted.
                      Originally posted by Gruelius
                      • woodisgood
                        • 1087
                        I wouldn't be doing this for weight reduction.
                        • LJ851
                          • 7919
                          Exercise?
                          Lorin
                          The M30 is God's engine.
                          • Kershaw
                            • 11822
                            exercise in futility?
                            AWD > RWD
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              Masochism.
