Damn you Harbor Freight tools
  • bernzpeed
    • 3917
    So swapped out the oil pan for my S52 and was torquing the bolts and the torque wrench did not click. Now I have a snapped bolt stuck on the block.
    Should I just drill it out, I am afraid of ruining the thread.
    Tips?
    89 E30 S52
    Transaction Feedback.
  • FredK
    • 14762
    Well, there's probably no tension on the bolt stub now that the head snapped off. You might be able to use Vise Grips on the stub after you drop the pan to remove the offending bolt if enough of it is protruding from the block.
    Isn't it 89 in-lb? I'm surprised HF has a wrench that goes down that low.
    • Roysneon
      • 4505
      There are tools that you buy from places like that and some you don't. Items like torque wrenches and digital calipers fall into the latter group.
      Originally posted by mbonanni
      I am a pursit now.
      • vert_this
        • Feb 2012
        • 395
        if enough of it is left you could use a dremel and create a slot to use a flat head to remove. You will most likely have to remove the pan and the other fasteners to do this though.
        • reelizmpro
          • 9557
          I never had a problem with HF torque wrench or digital calipers. I'd look into why it didn't work. Did u set it up right? It's real easy to set the torque wrong. And did u remember to lock it in after u set it? Try to dremel a flat head on it and unscrew it first before drilling.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • bernzpeed
            • 3917
            i think that i can try the vice grips and yes, i shouldn't have bought this there. I could probably return it for credit since it's over 30 days. and just get something else.
            89 E30 S52
            • Northern
              I like cupcakes & sh!tboxes
              • 5283
              If not(if it sheared at the base or something,) hit it with lube and properly use an easy out.
              Originally posted by priapism
              Originally posted by shameson
              • flyboyx
                • 8371
                well, some people have experience with turning wrenches and some people don't. apparently, you fall in the latter category. once you gain a little experience, you will "know" when too much torque is too much torque without breaking off bolt heads waiting to feel for the "click". cheap tools and a lack of experience that allows you to depend on cheap tools are a bad combination i am afraid.
                yes. this sucks but should be an easy repair by taking off the pan and using vise grips on the stud as mentioned above.
                by the way this thread sounds, you are blaming the tool. even if the tool sucks, you are to blame for breaking the bolt i am sorry to say.
                good luck getting it out. hopefully it will be an easy task
                Gigitty Gigitty!!!!
                • Herr Faust Schinken
                  • Feb 2012
                  • 3580
                  oh thats nice i just got bought some jackstands from harbor freight
                  88 325is Five Speed
                  Lachssilber
                  • bernzpeed
                    • 3917
                    vise didn't help, it just slips off. got a bolt extractor, we'll see how that turns out.
                    flyboyx, i was really going slow as i turned because i was waiting for the click. it never came.
                    89 E30 S52
                    • dannyg
                      • Mar 2007
                      • 1553
                      in for results of that lol
                      1993 325ic Schwarz/Natur
                      1991 318is Black/Black - Slicktop - Project s52
                      1989 Alpine White/Black M3 S52
                      1988 Henna/Pearl M3 <3
                      • LJ851
                        • 7919
                        Welcome to chinese precision tools. Hell, i got ass burned by a craftsman TQ wrench while my cust was waiting, never again.
                        Lorin
                        The M30 is God's engine.
                        • F34R
                          sLaughter
                          • 12376
                          You really did not have a little nagging in the back of your head that you're over doing it? lol
                          Instagram: @BWeissLeather
                          Current cars:
                          ~ '87 325 M30B35 swap
                          ~ '87 535
                          ~ 01 540 Msport 6spd
                          ~ '06 X5 4.8is
                          • LJ851
                            • 7919
                            Mine was a 2.5 lb ft handmade brass bolt, no room for error and hard to feel . I now own a snap on torque o meter that only goes up to 15 lb ft.
                            Lorin
                            • Bearmw
                              • 1323
                              For better or worse I got my son who is a senior in high school a 301 pc. HB tool set with "lifetime warranty" for Christmas for the total price of $168.48 including tax. I know some shit will get broken or lost and I know it will get used on his Schwarz 88is. I guess I'm a pragmatist. Hell I might even borrow a tool every now and then...and then swear like hell when it breaks.
