wtf is up with m42swaps?
  • J3M93
    • 448
    #121
    m40 for lyfe, I'm at 6k all day.
    Someone please give me an m42 :(
    • agent
      Vice Grand Pubaa
      • 7960
      #122
      Originally posted by Balkanac
      If you want speed get a skyline
      Uhhh... what?
      Originally posted by kronus
      • Balkanac
        • Apr 2011
        • 50
        #123
        Skylines are prob a bit harder to get in US but here they are everywhere. You get an r32 gtr, they are relatively cheap now, put $5k into the engine and get min 300hp at all 4s. That's what I call bang for buck!!
        1991 BMW 318is Brilliantrot
        1998 Jeep Cherokee TD Black
        • Swanny
          • Mar 2012
          • 2834
          #124
          Swanny!
          SUCKERS.
          • BlackbirdM3
            • 2769
            #125
            Originally posted by joolz635
            Well I have just done ALL if what you suggested. Big cams, solid lifters, duel springs, m44 valves(thinner stems and lighter) big port job, match porting, Dbilas itb's, 75mm velocity stacks, custom 4into1Exhaust headers. The head has bench flowed 234 hp. Has 11.0:1 JE ,ARP bolts , lightweight pistons, pauter forged light rods, teflon edged crank scraper, total seal rings, bosch blue top injectors, MoTeC m800 ecu, custom air intake, m20 lightened flywheel. Think thats about it. Car weighs 930 kg, has a 5small speed overdrive box with a 4.45:1 e36 318ti small case lsd. I will post results once I have them.
            Sounds like a fun motor to me. I find that a lot more cool and clever than just dropping a bigger motor in. It wasn't a cheap build by any stretch of the imagination, but neither is a motor swap so I'd say well done and have fun. 234 hp will move a 318 just fine.
            Will
            '88 BMW M3
            • decay
              • 5637
              #126
              Originally posted by CrusherCurtis
              It really has no desirable characteristics
              maybe none you care about.
              some of us want better than two-valve heads with rocker arms that shit the bed at less RPM than a new Kia can turn, sitting on top of a laughable compression ratio, being held together by a timing belt that looks like a rubber band (bonus points: only failure mode for that rubber band is "catastrophic").
              i can get all that AND make my car handle worse? swapping TOMORROW.
              past:
              1989 325is (learner shitbox)
              1986 325e (turbo dorito)
              1991 318ic (5-lug ITB)
              1985 323i baur
              current:
              • travish325
                • Jun 2012
                • 1151
                #127
                With a gallo 24 engine right?
                • Cletonius
                  • 2809
                  #128
                  Originally posted by 2761377
                  all i can say if you think all m10's suck, you obviously have never driven one with a kugelfischer pump.
                  Mechanical port injection? Link to how this works?
                  - Josh
                  1990 325is
                  Need a shift boot?
                  Looking to buy shift boot frames, PM if you have one to sell
                  Here's what happens when you let the internet pick your license plate
                  • gtdragon980
                    • Jun 2008
                    • 1808
                    #129
                    M20 >> M42
                    Plain and simple. More low end grunt, better top end, power band is smooth throughout, and sounds loads better than the m42. M20 all day!
                    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                    Originally posted by scabzzzz
                    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                    1989 325i - Project/weekend driver
                    2002 325i - DD
                    2005 Suzuki SV650 - Toy
                    • CrusherCurtis
                      • 2532
                      #130
                      Originally posted by gtdragon980
                      M20 >> M42
                      /Thread
                      • glucklich21
                        • 1912
                        #131
                        Hills and AC are not the M42's friend.
                        • eur04lif3
                          • Jan 2009
                          • 756
                          #132
                          Been daily'n an m42 and driven m20 before. Yes, you can tell the difference in HP's.
                          However, HP is not the sole factor when it comes to driving experience.
                          M42's are nimbler then m20s. For daily where MPG is a factor...i'd never swap it out.
                          That extra 5-10MPG that you get in an m42 is well worth the 40HP decrease.
                          AND on another note, ppl that swap m42's out benefit a good cause.
                          1. My car value increases.
                          2. Spare motors are in abundance (cheap), in case i'd FI one day.
                          Great read. :up:
                          • robrez
                            • Jul 2008
                            • 3376
                            #133
                            Someone said m42 vs. m20? Time for this classic debate then....
                            January 2012 COTM
                            • pmat
                              • Nov 2012
                              • 174
                              #134
                              You guys are argueing over the power difference between a 1.8L I4 and a 2.5/2.7L I6....
                              318is, m50tu g240 s3.46
                              • Holland
                                • Nov 2008
                                • 7204
                                #135
                                You're all bitches until you daily a stock M10.
                                Suck. My. Knob.
                                Originally posted by DEV0 E30
