Frame rail guards?
  • Calyx-E30
    • Apr 2013
    • 2
    Frame rail guards?
    Anybody heard or have a solution to bottoming out on your frame? I was thinking of some kind of thin hard plastic rail system, like old school skate board rails, to slide on rather than grinding on your frame over things like speed bumps. I have my exhaust raised now, but I can hardly make it over any type of speed bump. My buddy has a Lexus with rail guards like im referring to and he slides smoothly over them. Just wondering if anybody has seen or tried this on their E30? thanks...
  • TimKninja
    • 2131
    Raise your car.
    1985 325e M50TU(Sold)
    1991 318is Slicktop (Sold)
    1990 325is Brilliantrot S50/5 Lug Swapped.
    1992 525i Manual shitbox Winter Beater
    • evandael
      • Oct 2009
      • 2881
      Raise your car.
      • offsetmotorwerks
        • Apr 2013
        • 27
        Adding an inch of material will only make going over those bumps 10x more painful. You will go from grinding frame to high-siding.
        3rd, raise your car
        • lolcantturn
          • 4588
          Raise your car.
          Originally posted by TSI
          OEM+
          • slammin.e28
            שמע ישראל
            • 12054
            Cut out the frame rail with a grinder.
            • Lawn_Mower
              • Apr 2013
              • 21
              Frame rail delete!
              • ohthejosh
                • 4963
                replace with shower curtain rods for stability and rigidity
                SO MUCH MORE TO DO!!
                IG: ohthejosh
                LEGIT CHECK ME BRUH
                BUYER FEEDBACK THREAD
                • 10Toes
                  Me Father Was A Tree
                  • Jan 2008
                  • 61222
                  I think the PVC roll cage works better for the most clearance.
                  • slammin.e28
                    שמע ישראל
                    • 12054
                    No, make a PVC cage. Rigid, yet flexible. There's a writeup somewhere.
                    • smitche
                      • Feb 2013
                      • 326
                      Lower it
                      My Build Thread
                      • rturbo 930
                        • Dec 2005
                        • 2619
                        Raise your car.
                        • ZekeTheSneak
                          • 1562
                          Just scrape. Its chill
                          • Boostesi
                            • May 2011
                            • 220
                            go over the speed bumps diagonally, always worked for me not bottoming out
                            sigpicFellow e30 enthusiast
                            Dont waste your time hating, aint nobody got time fo dat
                            1986 bronzit 325es- SOLD
                            1987 delphin 325i- parts car
                            1990 scwarz 325is- m50 drift slut
                            CHECK OUT THE BUILD!
                            http://www.r3vlimited.com/board/showthread.php?t=229234
                            • ak-
                              • 12422
                              I laugh at everyone who does this with an e30.
                              If you go diagonally over a speed bump you WILL smack/scrape the pan.
                              Best method is take it straight forward as the pan is linear to your wheels. IS Lips can flex if they contact.
                              OP go around the bumps. E36's are worse off than us.
                              1991 325iS turbo
