Differences between early and late models
    • 34847
    My rear windows roll down :p
    • 2mAn
      SeƱior Mod
      • 21062
      Can someone clarify the differences between the fuel tanks?
      Simon
      Current Cars:
      -1966 Blue Boat
      -1969 Red VW
      -1986 White BMW
      -2006 Green Thing
      Make R3V Great Again -2020
      • rturbo 930
        • Dec 2005
        • 2629
        Originally posted by nando
        I dont think anyone cares about pop out windows and 26 year old headlights these days... condition is a better indicator of desireability than stuff like that. I never particularily wanted a 1989, a nice 90 or 91 is just as appealing.
        Not to mention the pop out windows are a pain in the ass to open and close unless you've got a backseat passenger. I'd like to see someone come up with a power window conversion, like the E46 has.
        As far as I know, the '88s have a bigger tank - 16 or 17 gallons, and all the other cars, both pre-88 and post-88, have 14-15 gallon tanks.
        • nyChris
          • Apr 2012
          • 395
          Wait a second... Late model coupes don't have popout rear windows?
          • Cabriolet
            • 9620
            from what i can remember:
            sealed beams headlights 84-86 and 90-93
            87-89 ellipsoid headlights
            84-86 etas early wire harness all interchangeable
            87 has its own harness and not easilly swapped.
            84-87 small fuel tank 14gl, 2 fuel pumps also has pipe below driveshaft
            88-93 16gl fuel tank, 1 in-tank pump
            84-9/87 early cooling system, even on 325i
            84-87 early seat rails and lower section of seat is different than 88+
            84-87 early, larger arches, except verts.
            87-93 all verts have lower rear arches
            84-88 pop out rear windows
            89-91 window trim is black not chrome and sealed rear windows
            84-89 solid steering column, 1 piece knee bolster
            90 vdo odo gears (as far as i have seen)
            88-93 173 or better DME
            84-87 early window regulators and glass
            88-91 late windows
            84-85 dont have cutouts for ski pass
            90-93 have airbags and different dashes
            87-4/91 verts have small tails and metal bumpers
            88-93 have the same valence and fog lights
            84-87 1 horn 88+ 2 horns
            88-93 late shift-linkage
            84-88 chrome on door guard trim
            Much wow
            I hate 4 doors
            • Thizzelle
              • 4422
              89M3 is best of best
              "I wanna see da boat movie"
              "I got a tree on my house"
              • camshaftgsxr
                • Aug 2011
                • 416
                early early models had different sidemarkers and front lips (84-85 i believe)
                BroWorks.com Bro is a lifestyle
                • TobyB
                  • 5297
                  Gas tanks, additional- (LHD car)
                  the late tank has a siphon system to transfer fuel from the driver's side to the passenger's. As noted above, 1 HP pump in- tank.
                  The early tank has a shallower driver's side, and an 'S' shaped pipe connecting the 2
                  under the driveshaft. Low pressure pump in tank, high pressure external 'pump
                  above the fuel filter, driver's side.
                  They interchange, if you transfer ALL the parts.
                  t
                  • rmdashrf
                    • Feb 2014
                    • 207
                    I have had a '90 and '91 sedan, both had chrome window trim. I believe only coupes of these years had shadowline trim.
                    • rturbo 930
                      • Dec 2005
                      • 2629
                      I believe it was only the 91 318is that had shadowline trim.
                      • rzerob
                        • Jun 2013
                        • 2315
                        Pop outs are easy to switch over to. I wrote DIY.
                        • Cabriolet
                          • 9620
                          that's the gutter rail and door trim. the actual window trim is black.
                          not talking about shadow trim.
                          late:
                          early
                          Much wow
                          I hate 4 doors
                          • rmdashrf
                            • Feb 2014
                            • 207
                            late:
                            early
                            Ah gotcha. My bad.
                            • cabriodster87
                              • Jan 2011
                              • 1042
                              Originally posted by McGyver
                              I don't know about sedans, but i know that the front windows between early/late are not interchangeable.
                              Isn't that because late mirror mount epoxied to inner surface?
                              edit: You meant front door windows, my bad.
                              Reich und Roll!
                              • JinormusJ
                                • 6887
                                Got to give it up to Eric for the comprehensive list. Seems just about right
