Stock E30 vs S5_ swap
  • Funboy
    • Nov 2014
    • 90
    On the horns of a dilemma : stock or S5_ Swap.
    I understand the appeal of the S5_ package
    But I have an acquaintance that is a racer from the late 60's in BMW and Porsche
    And was involved with BMW NA on the National roll out of the E30.
    He waxes poetically about the delicate 50/50 balance of the stock platform and
    How the S5_ weight would destroy it. So, light balance /sweetness or sledgehammer ?
    Any thoughts having done the transformation?
  • blunttech
    • 12850
    Im not normally one to pull the "search card" but this has been beat to death.
    Your partner has obviously not driven a well set up swap car. Unless youre talking e30m3 or M42 car the difference is easily overcome
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • Andy Mechnic
      • Jan 2015
      • 117
      A nose heavy car will push. And there is something magical about the E30s in their stock configuration, however, that can be quickly forgotten with an extra 100 horsepower. Besides who, aside from a race driver, or very sensitive street driver will really be driven nuts by a few extra pounds up front?
      • reelizmpro
        • 9558
        Audi S5 swap into the E30?
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • TRAK WDW
          • Aug 2014
          • 157
          Unless this is strictly a track/competition car, I would not worry about F:R weight with an S5X.
          Just enjoy the powerplant :thumbsup:
          Harp
          • mr2peak
            • 2388
            Do an alloy block m52 if you're worried about it
            Drive it hard. Maintain it well.
            A Topless Memorandum
            • phreshkid
              • 4655
              The handling of s5X swapped car can almost be completely corrected with the right combination of shocks/springs, swaybars, and tires.
              For example, I still had a lot of front end push with Bilstein Sport struts and shocks in stock housings, 440 lb front springs and 650 lb rear springs, vert front swaybar (with e30 m3 swaybar end links) and stock rear swaybar. I think I was running 225/45r16 tires too. I was pretty low, likely riding on front bumpstops because I didn't cut the strut housings.
              If I were to do it again, I'd probably go a bit lighter on the springs, shorten the strut housings and run the correct inserts, and either leave the swaybars stock or go vert front and something beefy and adjustable in the rear. Higher spring rate in the back also promotes oversteer, which to a point is actually better than understeer, assuming you can control it.
              That's the beauty of these cars; they react so well to upgraded suspensions.
              Get creative, and you'll soon find that that your theoretical problems can all be solved.
              Oh and get the car corner balanced if you do go coilovers. That sure helps.
              • Benjamin_Button
                • Mar 2014
                • 384
                Since you don't live in Cali, S5x
                ~Stay Thirsty~
                • phreshkid
                  • 4655
                  Meh.
                  My swap was legal and BAR'd. Very easy to do if you plan for it from the beginning.
                  • nl328i
                    • 556
                    There are other strategies too. When I s50 swapped my touring I notice kd thT despite having the battery located under the hood, the trunk recepticle was there as well. When I dropped in the s50 I re-located the battery to the rear. While the car may be a tad more nose heavy the power difference is worth it imo.
                    1976 2002, 1987 325is, s50 1991 touring, 1996 328i vert
                    • Andy Mechnic
                      • Jan 2015
                      • 117
                      I've always wanted to put a euro S50 in an E30. ITBs are such a thing of beauty.
                      • King Mufasa
                        • Sep 2012
                        • 530
                        What is the best 4cylinder engine besides the s14 right now of any manufacturer that is great for turbo and racing weight wise?
                        • Andy Mechnic
                          • Jan 2015
                          • 117
                          Honda B series
                          • kingston
                            • Jun 2010
                            • 2669
                            I track an S52-swapped sedan, and the front end is fantastic. Koni-based coils with 550/650 Eibahc springs, 22/19 sways and camber/castor plates. Castor is maxed out, -3.5 degrees of camber. Killer.
                            Originally posted by LJ851
                            kingston is the play by play announcer for this thread.
                            ‘Tis by the grace of God that my cars run!
                            Originally posted by unloadedak
                            #teamross
                            Siobhan's Build Thread - UPDATED!
                              • 34844
                              N52 :p
                              lighter than an M20, more power potential than an S52.
