A godsend for those with lowered cars?
  • Rob
    • 8166
    #31
    mad low m42 oil pan=maybach motorsports definitely has ramps.
    BEERTECH
    • Digitalwave
      is a poseur
      • 6302
      #32
      My jack has a 2.75" high saddle and it scrapes my frame rails when I slide it under. It can get the rails and the diff but I need to use the stock jack on one of the sides and lift that wheel of the ground before I can use it on the front subframe.
      RISING EDGE
      • Mystikal
        Wheel Fitment Expert
        • 9602
        #33
        My aluminum jack is only 3" or so high, and slides right under my car with room to spare. It was $99 at Costco, too.
        • rwh11385
          lance_entities
          • 18403
          #34
          god you must be lazy/stupid if you spend $80 on ramps
          my factory jack works on my framerail slammed and on undersized tires, and if you need to change oil.... craftsman floor jack can lift up by the jack points on the sizes quickly enough, one at a time. it's not that hard. geeez
          • IanBMW
            • May 2005
            • 34
            #35
            DK 13HLQ 2800lb Floor Jack with QuickLift Pedal
            TOL-13HLQ $518.95
            LMFAO, how about no.
            • BS87
              • 1606
              #36
              Originally posted by ToplessE30
              Pictures?
              Here, all i could find was the pic of my oilpan i took when i 1st got the cabrio.
              • moatilliatta
                • 6158
                #37
                just build jacks strait into the car...
                @Zakspeed_US
                • golde30
                  • 11464
                  #38
                  thats FUH RAZE!!!!!!!!!!!!!!!11111ONE
                  i also have the problem with the front subframe. have to jack up the side with OEM jack then put my floor jack underneath. diff is OK, frame rails are not.
                  IG: @Baye30
