1500 miles on timing belt, do i need new one?
  • cpandrewschmidt
    • Oct 2014
    • 88
    Hi all,
    Got my 1991 vert in the spring. did general maintenance items since i was the new owner and wasn't sure if/when things were done. water pump, belts, tensioner, thermostat, etc.
    I have a slow oil drip from the head gasket so now that the weather has turned i'm tearing it apart to put a new one in. I put around 1500 miles or so on it this summer and fall.
    Do i actually need a new timing belt if it has this low of miles? Can't seem to find any answers.
    Thanks!
    Andrew
  • Todd Black 88
    • Oct 2007
    • 3449
    Yes. The belt is only to be tensioned once
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • Klug
      • Sep 2011
      • 804
      Replace it- no need to skimp out on a few dollars.
      555Garage - Kingston, PA
      '13 BMW e70 X5 35d
      '95 BMW e34 525i
      '92 BMW e30 325i S52 Vert (Quade the Vert)
      '92 Range Rover Classic
      '90 Range Rover Classic
      '89 BMW e30 325i Coupe (The DIRTY30)
      '81 VW MK1 Rabbit Caddy Diesel
      '76 Honda CB550K Cafe/Brat
      '67 Pontiac LeMans
      '24 Model T Depot Hack
      ....And a bunch of Motobecane, Puch, Garelli, Batavus and Honda 49cc-78cc Mopeds...
      • kronus
        • Apr 2008
        • 13032
        what?
        cars beep boop
        • cpandrewschmidt
          • Oct 2014
          • 88
          sounds good, just making sure. The tensioner should still be good right?
          • Wschnitz
            • 8089
            The Belt is constantly tension-ed, there's no you can install it once BS.
            That being said still replace it, and if you're a fancy lad get a Gates racing blue belt, looks slick.
            willschnitz
            • mikebloco
              • Feb 2015
              • 190
              What ^Wschnitz said. Taking the belt off and then putting it back on doesn't cause it to stretch when it's back under tension. I would say if a belt has less than 1,500 miles on it than it's still new. Mine has 7,000 on it and it's perfect. My motor is torn down right now and I'll probably go with the racing belt because it's so cheap.
              • UlrichFennec
                • Dec 2014
                • 1268
                That's what I did! Gates makes some good stuff.
                "Leafeon" '92 Lagunengrun 325i Vert (Daily Driver/Project)
                http://www.r3vlimited.com/board/showthread.php?t=366044
                The stickers make it go faster. :nice:
                • Cabriolet
                  • 9620
                  Unless you are turbo'ing an m20 there is 100% no reason for a gates racing belt.
                  And just like everyone else has said you can reuse the old belt. But for $42 you can get a new one at your front door from Blunt.
                  Furthermore make sure to get a bmw head gasket and bolts. Have the head decked and pressure tested and valve seals replaced.
                  Much wow
                  I hate 4 doors
                  • Preyupy
                    • Oct 2012
                    • 73
                    And why would "turbo'ing" a M20 require a "racing belt"? The cam has no idea it is "turboed" Valve spring tension, cam lift and engine speed are they only things that will change the loads placed on the cam belt compared to the the stock loads.
                    • kronus
                      • Apr 2008
                      • 13032
                      engine bay heat.
                      cars beep boop
                      • Matt-B
                        The Waffler
                        • 3856
                        because racecar
                        if the pro3 guys dont use em, i would just get a stock belt
                        edit : that said, some of the 24v guys going sc or turbo, do add more heavy duty chains etc, for the same reason
                        • McGyver
                          • 4619
                          i would assume that a turbo allows for more load on the engine as well as faster changes in engine speed (acceleration) and changes in acceleration (jerk) which could put significant additional stresses on the belt, especially when the belt is changing direction around a pulley.
                          • Stanley Rockafella
                            • Aug 2011
                            • 4060
                            • rcsoundn1
                              • Nov 2012
                              • 3361
                              I would not replace it, but thats me.
