1500 miles on timing belt, do i need new one?
  • McGyver
    • 4636
    Originally posted by Stanley Rockafella
    as in going around the pulley versus moving in a straight line from the edge of one pulley to the next.
    so the angular acceleration and forces the belt experiences going around a pulley (which is related to position/time and diameter of the pulley)
    • Stanley Rockafella
      • Aug 2011
      • 4062
      phew, for a second there I thought you meant the belt itself goes in different directions (counterclockwise and clockwise) LOL
      • redsubdivisions
        • Feb 2011
        • 1762
        Originally posted by McGyver
        i would assume that a turbo allows for more load on the engine as well as faster changes in engine speed (acceleration) and changes in acceleration (jerk) which could put significant additional stresses on the belt, especially when the belt is changing direction around a pulley.
        WAT.
        Turbo M20 on a stock timing belt will be just fine.
        1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
        2012 Passat TDI - DD Duty
        2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
        • McGyver
          • 4636
          lol, nope. i hope not.
          Originally posted by redsubdivisions
          WAT.
          I'm not debating that, I was responding to an earlier comment that the timing belt wouldn't see a difference between a a stock NA engine and a FI engine. I can see FI increasing the load on the timing belt.
          • johnr617
            • May 2015
            • 33
            im thinking the only time you would need a racing belt is if you have an aggressive cam and stiffer valve springs or you're increasing redline severely. i would however spare the expense and get a racing belt ever on a stock motor since it is not much more expensive and its a bit of peace of mind. just my 2 cents
            • kronus
              • Apr 2008
              • 13032
              people chill we didn't have gates belts until like 2 years ago and everything was ok
              cars beep boop
              • Wschnitz
                • 8089
                I just got the Blue belt cause it was cheap and looks sexy.
                Itll look even sexier once I get rid of distributor and do an exposed cam gear for show ;)
                willschnitz
                • TobyB
                  • 5272
                  I'll throw pebbles in your general direction!
                  t
                  • Wschnitz
                    • 8089
                    t
                    Itll have a cover while driving dont worry.
                    willschnitz
                      • 34844
                      Originally posted by Todd Black 88
                      Yes. The belt is only to be tensioned once
                      wrong. It will be fine - done it more than once.
                      • jeffnhiscars
                        • Jun 2011
                        • 6011
                        Whether it's technically reusable doesn't really matter. It's the single most important (and talked about) maintenance item on an e30 and the conti I just bought (belt only) was about $13.
                        Why on earth anyone would change a head and not spend that for a new belt defies logic....unless you are so cheap you are also reusing your head gasket :)
                        Alice the Time Capsule
                        • Exodus_2pt0
                          • 5943
                          He isn't wrong, just because you haven't had an issue doesn't make it the correct way of doing things.
                          It is common practice and recommended by every auto manufacturer I've worked for.
                          No E30 Club
                          • fresh_TD
                            • Aug 2013
                            • 2457
                            But for $42 you can get a new one at your front door from Blunt.
                            $42 for a timing belt? Talk about getting robbed..
                            Sent from my Samsung Note 4
                            '91 318i (Alpine) - daily
                            '88 325ix (Zinno) - drive here and there!
                            • gte175x
                              • 150
                              It should be fine....the reason you replace them is fatigue(from bending and on/off tension) & or age(dry rot)....you have neither at 1500 mi. However, if you nick it or damage it in the process of removing it, you should replace it.
                              • Need4Speed1299
                                • Oct 2007
                                • 119
                                Use a Geotze head gasket and new studs. Reuse the belt.
