Sad day for my ix
    • 34839
    Originally posted by downforce22
    if you remove it together you have to drop it all out the bottom and lift the front of the car over the engine
    Wrong
    However, the easiest way would be to drop it out the bottom. Put a dolly under the subframe, unbolt everything, and pick the car off the assembly. But im not really sure it would really be much easier.
    • AndrewBird
      The Mad Scientist
      • 11898
      I forgot to add, put the rear of the car up on jacks stands and leave the front on the ground. This will give you a better angle for pulling the engine/trans out. Having a load leveler is also a HUGE help.
      • nomansland92
        • 1657
        Best way to pull the motor I've found so far, if you have access to a lift.
        Also if you need any bottom end parts like crank, rods, or pistons if have everything out of my motor before I built it. They have around 220k on them and I have another motor with 150k but I've never heard it run, either way I'll never use the parts and they will continue to just take up space so if you pay for shipping I'll give you whatever you need.
        Best of luck
        IX being restored here
        Ix turbo build here
        • TimKninja
          • 2131
          Join NE30 on facebook. theres a guy in MA that just wrecked his IX, think his engine is available.
          1985 325e M50TU(Sold)
          1991 318is Slicktop (Sold)
          1990 325is Brilliantrot S50/5 Lug Swapped.
          1992 525i Manual shitbox Winter Beater
          • johnt325ix
            • Nov 2013
            • 101
            Can't figure out what happened. 290,000 miles, has been burning a lot of oil lately. But ran great. On the highway, rapid ticking heard with loss of power. Put it in neutral immediately and pulled off the road. Car stalled. I started it up , the ticking turned to knocking and lots of smoke coming from engine bay. Car is still full of oil. Head gasket? Valve? No hole in block. Never overheated. Only odd thing is that the past few months The car got 24-25 mpg. Was always 19-21.
            • nomansland92
              • 1657
              Did it loose power over the last few months? Just for shits and giggles make sure the timing belt didn't jump from a bad tensioner. It would explain the knocking at least.
              Ix turbo build here
              • Exodus_2pt0
                • 5943
                Failing oil pump is my guess. Freed up mpg by the lack of parasitic draw from pumping full oil pressure. Then the engine eventually let out the magic smoke. Once the smoke gets out, the magic stops.
                Just an educated guess on the oil pump. Pop a valve cover and take a look around.
                No E30 Club
                • Nick's e30
                  • Mar 2012
                  • 676
                  I sold you those wheels last year for your son! Haha.
                  Sad to hear she's given out. An oil pump failing took down my original ETA motor from my first e30 too (not the convertible).
                  No antenna? I sell plugs!
                  Here: https://www.r3vlimited.com/board/sho...77#post4937877
                  • johnt325ix
                    • Nov 2013
                    • 101
                    What is the magic smoke oil because it through a rod bearing?
                    • ccsdo5
                      • Mar 2013
                      • 707
                      Sorry to hear about the IX :(
                      However I did see someone selling an M20 out of a IX in the tristate for sale section on here might want to see if he still has it.
                      Don't part it out though! I parted my IX out a couple years ago after blowing the HG, the past winter I really wish I still had. It shat on subaru's in the snow it was amazing.
                      -Dee
                      5-lugged turbo 318is Barn car
                      IG: @deebelmont
                      • AWDBOB
                        hooptie connoisseur
                        • Aug 2013
                        • 4433
                        Don't part it! There are PLENTY of strong iX motors around if you look. Before I relocated I had a few good iX bottom ends just sitting but no one wanted them so I scrapped them.
                        • kid325e
                          • Sep 2007
                          • 6421
                          I agree with everyone else... although...
                          if you decide to part, i'd like the front axles.
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • audiquattrot
                            • May 2008
                            • 3836
                            I sold a good ix motor couple years ago (everything attached) for $250 just bc I wanted to get rid of it.
                            www.instagram.com/snwmble
                            #snwmble
                            Current:
                            '05 BMW M3 - Silver Grey/Imola Red
                            '90 BMW 325iX - Sterling Silver/Houndstooth sport(5-speed converted)
                            '15 Mini Countryman - Blazing Red/Carbon Black
                            Past:
                            '01 Audi Allroad - Light Silver/Platinum Saber Black
                            '88 BMW 325iX - Diamond Schwarz/Silver sport *Sold*
                            '01.5 1.8TQ - Brilliant Black/Nogaro Alcantara ...after 8.5yrs, *Sold* =(
                            '90 BMW 325i - Schwarz/Tan sport *Sold*
                            '89 BMW 325ix - Diamond Schwarz/Black sport *Sold*
                            • 4tDX
                              • Jul 2014
                              • 507
                              • 101
                                • Jul 2011
                                • 764
                                I agree with the others here. It appears that you have an 88 IX coupe with manual transmission? If so, I think there's a law against parting those unless they they have terminal rust.
                                Hold tight for a bit if you can. Someone on here has an engine I'm sure. Members 2.5.12, packratbimmer and others in the IX technical section always seem to have some of these unique IX parts laying around.
                                101
                                The E30 collection:
                                1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                                1987 325is - Delphin / Black Sport (son #3's)
                                1987 325i Convertible - Triple Black
                                1989 325iX Coupe - Diamondschwarz / Black Comfort
                                1990 325iX Coupe - Sterling Silver / Grey Sport
                                1981 Fiat 124 Spider 2000 - Green / Tan
                                1998 Volvo V70 GLT - White / Tan
                                1998 Volvo S70 T5 manual - White / Taupe
                                2001 Ford Windstar - Silver / Grey (parts hauler)
                                2006 Lexus GX470 - White / Tan (tow rig)
