Oil change horror story
  • TobyB
    • 5298
    Jiffy Lube.
    Guaranteed- if you see that sticker, at the very least, the oil drain bolt will
    be fuckered, and there'll be a 'repair bolt' jammed in there.
    If you're lucky.
    t
    • redsubdivisions
      • Feb 2011
      • 1762
      You get what you pay for. Enough said.
      1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
      2012 Passat TDI - DD Duty
      2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
      • varg
        Florida Turbo Man
        • May 2014
        • 3438
        Originally posted by Stanley Rockafella
        IG @turbovarg
        '91 318is, M20 turbo
        • Bangalorre
          • Nov 2015
          • 16
          Brutal! When I went to the original forum post I saw a targetted ad on the bottom of the screen from Jiffy Lube. Gotta love automated marketing!
          Own:
          2009 335i Sedan - Silver with Black Interior
          1990 325i Sedan - Black with Tan Interior
          Restoring the e30 with 13 and 16 year old sons, started restoration in November 2015.
          • DrJosh
            • 2011
            Yeah, I saw that. I don't believe it.
            The mere fact that he owned the necessary tools should indicate that he knows the importance of having it done RIGHT, and that most of those quick lube places DO NOT have the trained staff and tools....so what was he expecting? a miracle for $49?
            Doesn't matter what you think. The guy was in he middle of a move and wanted a quick service. Oil changes are hard to mess up, and a shop that specializes in oil changes should be able to get the job done properly. It's not unreasonable to believe that a shop like Jiffylube can actually do an oil change.
            The guy got screwed. Do you really have to be a dick about it?
            Originally posted by Sonny
            I am a meme for our community.
            • fight4life28
              • Apr 2014
              • 821
              You get what you pay for......
              • TobyB
                • 5298
                Probably not holes cut in the bottom of the car.
                And the trans fluid dumped.
                That's a Jiffy Scroober that's WAAAYYYY off his meds, for sure.
                10-30 instead of 0-40? Yeah, maybe that.
                t
                • varg
                  Florida Turbo Man
                  • May 2014
                  • 3438
                  t
                  This. I know the people at those shops are frequently quite incompetent and even dishonest, double-gasket on the oil filter, wrong oil weight, stripped out plug, selling you services they don't actually do (flushes). But this was probably the worst case of a Jiffy Jab that I've ever seen. I mean, come on - there's incompetence, then there's outright headcase behavior, like cutting off a damn undertray.
                  IG @turbovarg
                  • b*saint
                    • 3794
                    Why would you even go there? They probably don't even use the right SAPS oil even if its the same weight.
                    Ma che cazzo state dicendo? :|
                    • totheredline
                      • Jun 2013
                      • 762
                      Don't be a prissy b1tch, change your own oil. Duh
                      = Heidi 1988 325 -> 335i. 7200rpm built M30
