If you had $3k to spend on your E30...
  • LateE30
    • May 2017
    • 210
    Let's say you start with an '87 Vert 5-sp. What would your priorities be if you wanted to restore the car to factory form but with some classy upgrades. This is very subjective, so I'm asking to hear all your opinions.
    Condition of the car; Pros and Cons
    Exterior:
    - Lots of normal wear and tear on the paint (swirls, nicks, light scratches)
    - No rust
    - Some dents and dings
    - Still glossy black shine when cleaned
    - Stock bumpers/lights/wheels, etc...
    - Manual top; condition of roof great, no tears or seam splitting
    - Rear window completely crusted over
    - Found a black window this morning that has made a home in the driver rear fender lining area.........
    Interior:
    - One crack on the dash
    - Carpet decent
    - Drivers seat big tear and foam on side bolster rubbed completely down to frame
    - Normal rear seat fading leather
    Drivetrain:
    - Engine runs great; no weird sounds (valve tick) when running
    - Weird squeal when starting the engine only
    - Clutch good
    - Slight hesitation from idle to blip the throttle (not sure if this is normal)
    - No smoke, no fluid leaks
    - Transmission seems fine (shifter is getting rebuilt already, lots of slop)
    - Smells like the cat isnt even there (passed CA emissions in 2014)
    Suspension:
    - Complete front end parts replaced 10k miles ago
    - Bushings, control arms, struts/springs.
    - It was a $2k job, have receipt
    - Rides really well, no squeaks or sounds going over harsh roads or bumps
    - No excessive roll or bounce
    - It handles like a convertible from the 80's......
    '87 Vert, Black, 5-sp
    '15 Civic Si, White - Daily commuter
    '15 MB C300 Sport, White/Cranberry - Wife's
  • cspec
    • Apr 2017
    • 182
    I would probably source a lot of parts from the junk yards
    Also the throttle maybe just a loose throttle cable
    • Metallated
      • Dec 2016
      • 1074
      If you don't like the early model front valence I'd do the plastic bumper and late model valence swap: http://www.r3vlimited.com/board/showthread.php?t=252047
      Maybe $500 if you search for good deals and do the work yourself, maybe a couple hundred more to get it painted.
      Personally I'd also pick up a set of bilstein and H&R springs for ~$600.;
      With the remaining $1500 I'd get euro elipsoids and HIDs for ~$500.
      Using carb cleaner on your ICV might settle your idle, and it's good to do anyways and costs a couple bucks, search for a nice write up on here.
      For the last $1000 I'd save and wait until something breaks or you find something you really want, if you want to spend it now though a nice set of 16" wheel would like nice especially with the tighter and lower suspension :D
      • flyboyx
        • 8371
        why this of course.
        /thread
        Gigitty Gigitty!!!!
        • roguetoaster
          Biggus Tippus
          • 7830
          It's a vert with bottlecaps, so I'd donate 3k to the local fire department and have them burn it for me, but only after removing the 5 speed swap.
          Then I'd make a thread on r3v about how I, a 17 year old, burn cars professionally and ask about which car should be next despite already knowing the answer.
          Or, you know, I'd fix the squeak in the engine bay and buy a hard top, either way.
          • ELVA164
            • 4861
            Sell front seats, get a pair of decent Recaros for a few hunnit
            Smoke test, electrical tune up
            Get a sssquid chip to remove the hesitation (normal thing for a stock chip)
            E36 steering rack
            Look into springs/dampers if you're unhappy with the current ride. I've heard a cross brace helps with cowl shake also.
            Get Bosch smileys and high output H1 bulbs. I guarantee you don't need more light output than that, and you keep stock wattage. Euro grilles, too.
            That should be around your total. If not, I'd do the suspension last since the stuff you have is fresh.
            • Hooffenstein HD
              • Nov 2012
              • 1388
              3K should complete my rear lump sump, aluminium block M52B28 swap.
              • e30davie
                • Apr 2016
                • 1788
                I opened this thread and thought it was Christmas.
                Set goals for car, realise what items need replacing in order to reach goal, spend as little as possible doing items.
                If you start with the idea of spending 3k, you might spend it all and not achieve your goal.
                • E30 Wagen
                  • Jul 2005
                  • 3434
                  Have the seats repaired/reupholstered and deep clean the carpets and door panels.
                  Have a pro do some pdr/paint correction - make sure he doesn't do something stupid like drill into the body for pry bar access. Or there's plenty of youtube videos that can show you how to do it all yourself.
                  Fix all mechanical shit.
                  Repaint or replace all the faded black trim, ie grills
                  15" wheels and tires
                  Performance chip
                  Plastic bumper swap
                  Done
                  My Feedback
                  • 101
                    • Jul 2011
                    • 764
                    I also have a triple black, bottle-capped, diving board equipped 87 convertible. E30 Wagen's list is exactly what I would do, except I'd keep the diving boards and replace the top and tension straps if the window is totally frosted over.
                    I also relocated the fog lights outboard on my car to line up with the parking lights. It's a much better look IMHO and no longer looks like a 15 year old went to Pep Boys and bought a $30 set of lights to add on the bumper.
                    101
                    The E30 collection:
                    1987 325es M52 - Schwarz / Taurus Red Sport (son #2's)
                    1987 325is - Delphin / Black Sport (son #3's)
                    1987 325i Convertible - Triple Black
                    1989 325iX Coupe - Diamondschwarz / Black Comfort
                    1990 325iX Coupe - Sterling Silver / Grey Sport
                    1981 Fiat 124 Spider 2000 - Green / Tan
                    1998 Volvo V70 GLT - White / Tan
                    1998 Volvo S70 T5 manual - White / Taupe
                    2001 Ford Windstar - Silver / Grey (parts hauler)
                    2006 Lexus GX470 - White / Tan (tow rig)
                    • varg
                      Florida Turbo Man
                      • May 2014
                      • 3413
                      I'd buy the supplies to do the body work and paint, replace the bumpers and missing trim, re-upholster the driver's seat, and have the head rebuilt/block o-ringed so it'll stop burning oil and I can turn up the boost. That's all that really needs to be done for me to be satisfied with it.
                      IG @turbovarg
                      '91 318is, M20 turbo
                      • LateE30
                        • May 2017
                        • 210
                        hahaha, i got a good laugh from some of you, totally what i expected on such a subjective thread. this isnt my first car, nor my first build, however it is my first BMW and i happen to not know anything about the community.
                        I appreciate everyone's input, i actually have more of an understanding of what most of you are prioritizing, very helpful.
                        Keep 'em coming! (especially the troll posts)
                        • IronJoe
                          • 2275
                          I am doing something very similar! Started with a triple black bottle cap diving board 'vert:
                          And $30k later:
                          Wait... did you say $30k or $3k? :???:
                          '89 Schwarz E30 M3 Cabriolet Build
                          • Rusty.Piranha
                            • Mar 2017
                            • 660
                            hahah damn dude!
                            • E30 Wagen
                              • Jul 2005
                              • 3434
                              If the rear subframe and trailing arm bushings haven't been replaced I'd replace those also. Never owned a cabrio so I can't speak from experience but a strut brace and chassis brace may have a big effect on how the suspension feels, probably worth trying that out before going with a stiffer shock/spring.
                              Honestly I think I'd just leave the stock bumpers alone because it's a lot of work swapping to plastics, plus you're left with holes in the trunk from removing that trim piece. The cowcatcher 325is front valence looks great, or there are others made by Zender, Pfeba, Racing Dynamics, etc, that are designed for diving boards but are harder to find. Good luck finding a rear apron. I've been wanting a smooth and quiet m50 swapped face-lift cabrio to cruise in myself, ideally black with a gray interior, including the uber rare matching gray dash.
                              My Feedback
