Brick Resistant Windshield Film??
    • 34844
    #46
    You're doing it wrong - our kids have a dedicated room for Lego. They probably have at *least* 100,000 peices and I have never stepped on one. :p
    • ELVA164
      • 4861
      #47
      Originally posted by agent
      Little known fact: the 1988 Mazda RX-7 has the thinnest windshield glass of any passenger car sold in the United States since the advent of tools accurate enough to measure such things.
      Calipers?
      • TobyB
        • 5279
        #48
        I feel a little better now. I drive along, in the right lane, with my tinfoil hat on
        worrying that I didn't tighten the idler on the cam belt enough, or that maybe the
        nut will fall off the oil pump, or that the nut on the onramp will suddenly veer into me.
        Now I know that there are people out there that have an even worse time of it than I do.
        Phew.
        Thanks, OP, I feel a little better now.
        Now I'm off the replace the o- ring between the oil thermostat and the block,
        because I'm pretty sure it's about to fail, instantly dumping oil all over my rear
        wheels, and causing a horriffic accident involving me spinning into a truck carrying a load
        of bricks, hitting the 'dump' lever, and bricking a dozen cars all around me. I'd be a
        parallel killer, then.
        hee.
        You're right, it's r3v!
        t
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5586
          #49
          I've spend the last 10 hours, tirelessly working on a solution, for this problem and I'm proud to present my latest prototype.
          The Helmet-ermelon
          • flyboyx
            • 8371
            #50
            Iiiiii liiiiiiike!!!!!
            Gigitty Gigitty!!!!
            • stonea
              • 2892
              #51
              Originally posted by parkerbink
              Stay home.
              /thread.
              Thats still an equal deadly option.
              My Garage
              Feedback
              Instagram: Stone.Hopkins
              • Mr. Tasty
                • Jul 2011
                • 3421
                #52
                OP be careful of house fires and home invasions.
                2014 Alpine White 335i MSport
                (Daily Driver)
                Full Mperformance Aero
                KW V2 Coilovers
                VRSF Catless Downpipes
                • agent
                  Vice Grand Pubaa
                  • 7960
                  #53
                  Originally posted by ELVA164
                  Calipers?
                  I meant while the windshield was installed in the car.
                  That or I just made it up. ;)
                  Originally posted by kronus
                  • TobyB
                    • 5279
                    #54
                    Put a brick through it. Then you can caliper it.
                    heh
                    t
                    • Streichholzschächtelchen
                      • Jan 2009
                      • 1670
                      #55
                      Lateriphobia, Touvlophobia
                      Jah bless! :pimp:
                      • McGyver
                        • 4637
                        #56
                        OP:
                        While you may be worried about bricks through the windshield, wouldn't a better use of your time/money be spent on replacing all the worn-out/Chinese suspension components, flushing brake fluid, replacing pads/rotors, and making sure you have good tires that are properly inflated on your car?
                        I would assume you are much more likely to die or be seriously harmed from lack of maintenance or use of cheap parts for critical components.
                        Do you have your ABS working?
                        • ELVA164
                          • 4861
                          #57
                          heh
                          t
                          My thoughts exactly!
                          • ELVA164
                            • 4861
                            #58
                            I'm honestly hoping you didn't make up the thickness thing. I've already added that to the factoid database.
                            • djjerme
                              • 5082
                              #59
                              Shoot there was house flattened on the coast in Gearhart a few years back by a small plane crashing in to it. Killed half the family.
                              In the end, we're all spinning wildly through space on a giant rock that if it even altered course a couple degrees would probably kill every living thing on it's surface.
                              2016 Ford Flex
                              • TobyB
                                • 5279
                                #60
                                Then quit pushing on it, you freak! You're going to kill us all!!!!
                                hee
                                t
