e30 m3 appraisal
  • haigoshig
    • Mar 2018
    • 2
    e30 m3 appraisal
    I came across an e30 m3 that was parked in front of this persons house. I talked to him for a bit and he told me a few things about the car. It has a clean title, 250k+ miles, and m20 swap (yes you heard me right an m20 swap in an e30 m3!). The car has a rust spot right where the wiper blade is under the windshield. I'm not sure of any other rust under the car. Also, there were rats living inside the engine bay and who knows where else. It's a pretty rough car I will say. Overall I just wanted to get an estimate of what you guys think this car is worth. It's a legit e30 m3 but it does not have the s14 :/. Let me know what you guys would appraise this e30 m3 at. Thanks
    Update: I picked up the m3 for 5k!
  • Replicam3cabrio
    • 801
    Pictures are not showing much detail, if it is in all original aside from the engine and it has vin tags and no accident is worth $18-20K
    • reelizmpro
      • 9553
      Really rough looking M3. M20B27 ETA engine installed. I'd price it as a complete roller which is about $20k in today's market whether we like it or not.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • roguetoaster
        Biggus Tippus
        • 7830
        Good heavens, and it won't go for a penny less than 15k.
        • e30davie
          • Apr 2016
          • 1788
          I wonder what happened to the original motor. shes pretty rough, but looks somewhat complete.
          If you could get it cheap enough, remove the m3 badge and tell everyone its an uber rare widebody 325e!
          • uturn
            • Dec 2010
            • 1006
            This is the perfect roller I need for my M30 swap!
            • Andre3127
              • Dec 2017
              • 291
              I believe these cars have a problem spot with rust around the windshield, but I'm not certain on that. Since you mention rust around the wiper, make sure it's nothing bad.
              Sent from my XT1053 using Tapatalk
              Budget E30 Parts - Used and Reconditioned parts for your BMW
              • Replicam3cabrio
                • 801
                The problem becomes after a windshield replacement, it has drain holes they normally get plugged if the installer isn't careful, the water has no way to scape creating a weak spot.
                • Stanley Rockafella
                  • Aug 2011
                  • 4062
                  Nice, it's got the M20 B27 upgrade! ;D
                  Probably the SLOWEST e30 M3 on the planet
                  As for value, I'd say fourteenkay and not a penny less!
                  :nice:
                  • djjerme
                    • 5082
                    You're buying a shell.
                    Needs repaint, complete drivetrain.. Price as such.
                    2016 Ford Flex
                    • Javier h
                      • Sep 2007
                      • 1189
                      Ouch
                      As tempting as it maybe, no more than $20k
                      Swapped S52 with nice paint can be had for $30k.
                      But I would try to secure it in the vicinity of $15k, if you really want the car. Considering the rust and unknowns, this will start to add up quickly.
                      • 2mAn
                        SeƱior Mod
                        • 20997
                        at the same time, you might have found one that the seller doesnt know what its worth. I imagine that if you showed up with $10k and a trailer, they might be extremely happy
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • kronus
                          • Apr 2008
                          • 13032
                          put down the crack pipe
                          cars beep boop
                          • ncsubowen
                            • Nov 2013
                            • 1012
                            This car was likely picked up for less than 5k with a blown s14 back in 2000--2005 so keep that in mind. I'd show back up with like 10k in pocket and offer 8 to see if you can get it without the owner going online and jacking up his expectations. Otherwise you're looking at a lot of hassle and money to get it back up and running.
                            4 doors.. so much room for activities!
                            IG @bluebombr
                            Transaction Feedback:
                            http://www.r3vlimited.com/board/showthread.php?t=323622
                            • jhaurimn
                              • Nov 2012
                              • 2224
                              Be prepared to be dealing with some serious firewall rust based on the rust below the windshield, it doesnt look good. You might get lucky, but youll want to be prepared for the worst there.
                              Is that a glass moonroof? Cant tell if it is, or its just a sunroof with good paint surrounded by crappy paint.
                              Definitely look underneath for more rust. If its been sitting outside for an extended period of time, theres probably more rust underneath.
                              Current:
                              1989 325i
                              1988 M3
                              1987 325ic
                              Past:
                              2001 330ci
                              2001 M3
