I had to see how much the M42 sucks, so today I test drove a 98 318ti (5-speed M sport). Okay, it has M44, so I still don't know how much the M42 sucks, but I love the M44! Whoever thinks it's too slow is smoking crack. It's quicker off the line than my M20 and loves to rev! Seems like the perfect match for the E30. :D
Which engine would you choose for a swap?
This isn't an N52 discussion though (although I'm sure it's a great engine!). M54 is great too, it's fairly lightweight, but a good portion of the weight will still be in front of the axle and it doesn't like to rev like the 4 cylinders. It was designed for low down torque to power the big X5 SAV. So I think it's at home more in a larger vehicle. For little cars like the E30 I'm beginning to think that little engines that like to rev are a better choice, at least they seem to bring more of a smile to my face, cause I'm still smiling after driving that 318ti.
Originally posted by Andrew325is View Postloves to rev!
As for the MM 2100 rally engine, there probably isn't a more expensive way to go about making 205hp other than an S14 swap.Last edited by varg; 07-11-2019, 07:18 PM.
IG @turbovarg
'91 318is, M20 turbo
[CoTM: 4-18]
'94 525iT slicktop, M50B30 + S362SX-E, 600WHP DD or bust - updated 3-17
M42 is a economical motor when stock. But it doesn't sound good, is super buzzy on the highway especially with the 4:10's 318is have. And the cost for parts is really disproportionate to the performance. Check the prices on a timing guide or oem motor mounts, the only ones you should be using.
Sent from my SM-G970U using Tapatalk91' 318is 90' 325is
Originally posted by SonnyBuy the E30s, they ain't gonna last long
E30 can make you, E30 can break you
I've had an Eta, an I, and M42. The only thing the M42 has going for it is lighter weight over the nose. Its fun but like someone said above, the cost to performance ratio is bad. Then you add the weak points. Tensioners, profile gasket, timing chain guides, thrust bearings. Bags of meh.
Sign me up for either the s14 or the m54.
Originally posted by Julien View PostAFAIK the N52b30 is lighter and makes a boatload more power
Try again caller
An S14 is just under 240 lbs
A quick Google on the N52B30 has it around 355 lbs
You were close though.Last edited by JimmyP; 07-11-2019, 09:20 PM.Jimmy P.
87 E30 M3 Prodrive British Touring Car
88 E30 M3 Zinnoberot - Garage Queen
88 E30 M3 Lachsilber - SCCA SPU #98
92 M Technic Cabrio - S14 Powered!
98 318Ti Morea Green
04 Ford F350 Dually Tow Machine
Originally posted by JimmyP View PostYou missed the N/A part.
Try again caller
So heavier yes, but still way more usable power.
Try again caller
yeah no turbos on the n52b30.
Also why the dick-ish attitude? Is it because you blew all your money s14'ing everything before you realized it's mediocrity?
I wouldn't call the S14 mediocre. If they were that bad they wouldn't be worth thousands of dollars. N52s are worth peanuts, less than M54 for some reason. Not sure why. Bargain if you can get one running in an E30.
Speaking of bargains, here's an S14 at auction in the UK someone might be able to a get a deal on. Doesn't say how many miles and no info as far as health of the engine like compression, so assume it needs a rebuild I guess. Doesn't say which variant, but maybe S14b20? I messaged the seller yesterday and haven't got a response. Might be a scam, but they've been a member since 2015, so who knows. Current bid is $2k with 2 days to go.
S14b20 is real, pretty rear from my understanding. Check out the 320is.
My bad on the N52, I thought all N motors had turbos.
I'd love a Mag /Alu block for an S14,,, but not interested in the size and the added weight of an N52.
I can lift an S14 block w/ crank, pistons, rods from the floor to my bench. They dont weigh much at all and they are a small package.
If you think the S14 is mediocre, carry on with your grocery getter engines.
I'll take 'em all.
Most of the people that bag on S14s, know really nothing about S14s.
S14B20 is a 2.0 litre versionJimmy P.
Originally posted by JimmyP View PostAn S14 is just under 240 lbs
Engine weight figures are completely meaningless without information about the state of the motor when weighed.
IG @turbovarg
[CoTM: 4-18]
