Dyno Tomorrow
  • markseven
    • Sep 2006
    • 5327
    Dyno Tomorrow
    Hey Guys,
    Tomorrow I'm dynoing the 325 (stock M20 with a Jim Conforti chip) at Autowave in HB. Is there anything special I should do prior to the Dyno runs? Is there anything I should make sure the tech addresses beforehand?
    I just changed the engine oil/filter and the air filter, BTW
    TIA,
    Mark
    I Timothy 2:1-2
  • zaust
    • Jan 2007
    • 200
    Clean air filter and make sure there is no air leaks.
    325i touring, 327i 2 tone tech 2, 335i tech 1 touring with nossigpic
    • markseven
      • Sep 2006
      • 5327
      Do you mean air leaks around the filter box / AFM or vacuum leaks?
      I Timothy 2:1-2
      • zaust
        • Jan 2007
        • 200
        Vacum leaks fella..
        • markseven
          • Sep 2006
          • 5327
          No one else? :neutral:
          I Timothy 2:1-2
          • Digitalwave
            is a poseur
            • 6299
            Strap it on, be dissappointed.
            RISING EDGE
            • markseven
              • Sep 2006
              • 5327
              Werd. I'm not looking for big numbers, just a solid baseline for shift points and torque curve. I'm expecting 140hp at the wheels.
              I Timothy 2:1-2
              • express_wagon
                • Oct 2006
                • 57
                Get a video and post results
                • markseven
                  • Sep 2006
                  • 5327
                  I'll post the results for sure, but I don't own a video camera, although I may take the leap into the 1990's and buy one :D
                  I Timothy 2:1-2
                  • soul
                    • Jan 2007
                    • 23
                    sweet, make sure to post up results. i'd like to have a car to compare mine to. (good running m20 vs. dying m20 with an oil leak)
                    • ptownTSI
                      • Jun 2005
                      • 1265
                      141.5 peak
                      • markseven
                        • Sep 2006
                        • 5327
                        Results
                        Here's the data:
                        147.3 HP @ 6200 RPM
                        148.0 Ftlb @ 4300 RPM
                        If BMW and Conforti's advertised numbers are correct, (167/177 HP and 164/177 Ftlb), then I am experiencing a 16.11% HP drivetrain loss.
                        Check out the AFR graph - what do you guys think? Lean?
                        I Timothy 2:1-2
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Looks lean to me, especially in the upper RPM's.
                          • markseven
                            • Sep 2006
                            • 5327
                            Here she is on the Dyno
                            I Timothy 2:1-2
                            • markseven
                              • Sep 2006
                              • 5327
                              Yeah, I have to look into that.
                              I Timothy 2:1-2
