Dyno Tomorrow
  • markseven
    • Sep 2006
    • 5327
    #31
    Nevermind :p I just read a tech article that reveals the limited increase in power gained from a more complex approach to the hi-r3v-lean issue ;)
    -Mark
    I Timothy 2:1-2
      • 34844
      #32
      I think you mean variable fuel pressure regulator, not fuel pump. I prefer the one IE sells, since it bolts up to the stock fuel rail with no adapters or other BS, and it comes with a gauge.
      • backtrail69
        • Jul 2005
        • 4471
        #33
        The only real way to fix all the problems with motronic is to get a standalone and dyno tune it perfectly and it removes the AFM for MUCH better throttle response. Driving my 325is w/ MS...then getting in my eta sucks... AFM and motronic FTL...but great for DDing.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • markseven
          • Sep 2006
          • 5327
          #34
          Thanks, mang - I checked out the IE model, $245... looks nice though.
          I Timothy 2:1-2
          • Digitalwave
            is a poseur
            • 6299
            #35
            You shouldn't be running that lean anyways. Instead of compensating with more fuel, find the real source of the problem, i.e. a vacuum leak or clogged injectors.
            RISING EDGE
            • Jscotty
              • Jan 2007
              • 2285
              #36
              Kinda off the subject but looking at that pic, I couldn't help but to think what would happen in the event that the dyno jammed up and the car went flying through the garage! I guess that must have happened before because the last time I went with my buddy to have his car put on the dyno, they hooked this heavy chain to the tow hook in the back.
              • gstuning
                • 833
                #37
                That is not a variable rate fuel pump but a variable pressure fuel regulator,
                you can find one cheaper on ebay I´m sure.
                Gunni
                @ Prodrive / Aston Martin Racing
                • tomgt325
                  • Jan 2006
                  • 472
                  #38
                  getting mine done tomorrow....
                  i have a friend that works at a shop. with apprx. 240-250k miles on her, im only expecting like 120-130 whp. absolutely everything is stock.
                  • markseven
                    • Sep 2006
                    • 5327
                    #39
                    True. It's on my mind 24/7 - hopefully I'll have it diagnosed soon...
                    Haha, my car wasn't tethered! All it had was a chok block in front of the DS front wheel... :p
                    Originally posted by gstuning
                    That is not a variable rate fuel pump but a variable pressure fuel regulator, you can find one cheaper on ebay I´m sure.
                    Yeah, if it comes to that I will def scour eBay :)
                    Cool, man! Post up! :D
                    I Timothy 2:1-2
