Late Model iS Factory Side Skirts...Part #'s Inside!
  • DarkWing6
    • Apr 2004
    • 7144
    #31
    Those look better without a rear apron than I thought.
    • BS87
      • 1606
      #32
      Originally posted by Mike 91 318ic
      I'm not 100% sure the won't, but the rockers are taller and have a slightly different angle. Generally skirts for cabrios are cabrio specific. Maybe with some modification they could be made to fit? Jordan will probably know.
      M
      I seem to remember jordan saying that you could make most except the mtech 2 fit within reason.
      • CleanAzzE30z
        • Jan 2004
        • 11794
        #33
        Will these fit 4 doors? This couldnt come at a better time since Im upgrading my bumpers to the newer style. I havent seen these in a while. Thanks Ryan.
        • Digitalwave
          is a poseur
          • 6293
          #34
          Yes they can.
          RISING EDGE
          • reelizmpro
            • 9530
            #35
            Originally posted by 318driver
            Were these side skirts like an option when the person bought the car new??
            I've seen them in person and I don't think they fit convertibles. Hard to explain but converts have more "area" under the door than the other E30's. You need bigger sideskirts that are designed for the iC.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Chris E30 Cab
              • 866
              #36
              Barry is right.......my pal has them on his 4dr M40 stroker and they just are not large enough to cover the rocker panels on the cabriolet.
              • uberpanzer
                • 110
                #37
                So then how would they fit a 4dr? I thought the 4dr's had more length in the rocker panel area too?
                SOMEBODY messed with my sig so now you get this one:
                • Chris E30 Cab
                  • 866
                  #38
                  Don't think so.....at least my pals rocker panels don't look as tall as my cab.....but never measured it. It's not length but height that is different between the cabs rocker panels and the hardtops.
                  Anyhow, the ETK only shows the first generation M-Tech skirts and second gen. M-Tech skirts as options for the cab. Also, it shows the 2dr & 4dr hardtop sport skirts as the same p/n.......51-71-1-947-063 & 51-71-1-947-064 for the long main section.
                    • 34839
                    #39
                    no, 4 doors have the exact same dimensions. you may be confused with the E36, where the 4 door uses a completely different chassis.
