e30 fixes for common problems
  • ian e30 318is
    • Mar 2007
    • 1809
    #31
    hammers always work for me. :D
    1991 LS1 Swapped 318is
    Instagram:
    https://instagram.com/saltybeast/
    LS Build Thread:
    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
    • redbull 325is
      • 7471
      #32
      till ya fuck a thread up.
      Build Threads:
      • dtdub
        • Nov 2007
        • 34
        #33
        Originally posted by redbull 325is
        I've never seen that gasket leak on any e30. Replace the whole control arm, it's a worthwhile investment. Try to replace your shocks/springs (if they are worn, or you want to lower your car) at the same time so you don't ruin the balljoint's boot down the road..
        Yeah, I am trying to replace the struts and springs... that's how I busted the ball joint boots.:roll: Got some Koni sports and H&R sports itching to go in!
        www.SpitfireEFI.com Custom Megasquirt ECU's
        '91 318is
        • kyle wilson
          • 58
          #34
          how do i get my e30 to not have mold on the inside of the convirtable top
          wilson
          • redbull 325is
            • 7471
            #35
            Make sure it's dry when you store it.. Once it's dry spray some convertible spray on the canvass to make it water resistant (i think bavauto.com sells the stuff). Maybe take some mildew soap to clean whats on there now first?
            HTH
            Julien
            Build Threads:
            • Julien
              • 7471
              #36
              o.O
              Build Threads:
              • Sea Aych
                • Apr 2013
                • 766
                #37
                awesome! fixed my wipers right up with number 28!
                1988 Atlantisblau Euro/Japanese 325i Cabrio
                1989 Schwartz 325i - now M50 powered! - now very dead
                1998 Toyota 4Runner Limited - gone
                My 17,000km Big NA National Parks trip!
                • Thehemiman
                  • Apr 2009
                  • 533
                  #38
                  Originally posted by Julien
                  1. Steering wheel clunks while driving over a bump but control arms/tie rods are in good shape: Tighten the big nut on the steering colum inside the car close to the floor (airbag cars only)
                  I noticed this in my new 318is and assumed it was due to the suspension. I plan on replacing it all anyways but I'll have to give this a try for the time being.
                  1988 325i Vert
                  1991 318is Slicktop
                  • quikveedb2
                    • Sep 2007
                    • 2258
                    #39
                    Wow, '07 comin back at ya.
                    You know why you're drinking that Pabst? No its probably not because it was the first beer you grabbed. It's because you're a winner.
                    • Coupelx
                      • Oct 2013
                      • 169
                      #40
                      on separating ball joints, most times a couple good hits where the 'shaft' passes though the spindle will release it. for stubborn ones placing another hammer on the spindle like a punch and hit on that. no one should own a pickle fork.
                      • sonomabimmers
                        • Dec 2015
                        • 802
                        #41
                        this is all so true and perfect and really helps if i had found this a year ago i might swear less lol.
                        "19. Easiest way to remove the top bolts of the tranny: from the top (under the car) using loooong extensions"
                        those fucking starter bolts. this whole thing is genius
                        i love bmws
                        • sonomabimmers
                          • Dec 2015
                          • 802
                          #42
                          can you answer this for me http://www.r3vlimited.com/board/showthread.php?t=383747
                          i love bmws
                          • estoguy
                            • May 2013
                            • 1087
                            #43
                            For the outer tie rod ends, you can use a copper hammer to hit on them... less chance of screwing up the threads.
                            Estoguy
                            • Kershaw
                              • 11822
                              #44
                              Copper hammer? What are you, Bill Gates?
                              Use a brass hammer. They're $5 at harbor freight.
                              AWD > RWD
