Redline MTL... Yummy
  • Jean
    • 18228
    #61
    Originally posted by tonytony
    joe's sports was going out of business so i stocked up on some royal purple 5w30 motor oil and some how ended up with two atf oil(bottles look the same). Anyway since i have the oil will it be ok to put ATF in my tranny? I have a 91 g260 if that makes any difference. The answer is probably yes, but I just wanted to make sure it's legit
    Look at the tranny case and see if it's got an ATF Sticker.
    • pawi30
      • May 2007
      • 1091
      #62
      Originally posted by nando
      I'm using redline "shock proof" in my transfercase. that shit is fucking nasty.
      which one did you chose?
      heavy , lightweight, or super light?
      Originally Said by Bob Marley
      "BMW make pure trouble!"
        • 34834
        #63
        heavy, I think. I still have the bottle, I can check later this week.
          • 34834
          #64
          it doesn't really matter, there's no difference between the two.. it was probably just cheaper for BMW to put ATF in the transmission. it will shift WAY better and likely last longer with gear oil in there instead. I would never put ATF in a manual transmission. Mine is a "green label" (ATF) and it's still purring at 260k with redline 70w80 MTL. :)
          • SamE30e
            • Sep 2007
            • 4319
            #65
            I'm running Amsoil Severe Gear 75W90 in my diff.
            1985 325e 2.8 Turbo VEMS
            • TS87325IS
              • Sep 2006
              • 821
              #66
              green lable is for synthetic fluid , red lable is for atf , no lable is regular mtl , that is what the stickers mean on the transmissions , and yes some do make a difference what fluid you put in them , red line mtl is synthetic so it will go in a green lable or a no lable trans just fine , if it has a red lable , I would personally put atf in it, but to each his own.
              mods: just meat and potatoes under the hood and wheaties on fire out back ;)
              • txtorquemade
                • 1758
                #67
                Just ordered from BavAuto
                4 x 75w95 Redline diff fluid... ( I have two to do)
                2 x 70w80 Redline MTF
                1 x 5 liter Lubomoly engine oil 10-40w
                clutch slave cylinder
                3 Mann oil filters
                sigpic 1987 325is
                  • 34834
                  #68
                  I checked, it's lightweight Shock Proof. still pretty gooey.
                  • 8380 Labs
                    • Oct 2006
                    • 2990
                    #69
                    i stumbled onto this thread while doing some research on changing out my trans and dif fluids.
                    did the transmission last year with the redline and that was a nice improvement. finally got around to doing the dif fluid today (redline also).
                    1) old dif fluid really does smell like a butthole.
                    2) this was probably the best bang for the buck things i've done to the car yet, it was a DRASTIC improvement. i have no idea when the fluid was last changed, but it stank and was pretty dirty looking.
                    i had issues at low speeds where the car would buck and i had to be very gentle with the clutch to drive smoothly. post-redline the issues are completely gone.
                    i still need to do a guibo and CSB, but i'm very impressed with the redline fluids thus far.
                    8380 Laboratories
                    M3 Champs Poster
                    • Ian Bowers
                      • Apr 2008
                      • 1120
                      #70
                      So, say I put redline MTL in my Getrag 240, and the shifting has gotten considerably notchier/poorer feeling in general. Transmission has an "ATF" sticker on the side -- refill with redline ATF, or the 70w80?
                      • gverelli
                        • Dec 2008
                        • 772
                        #71
                        ^^Im in the same situation, feels like it got worse especially when its cold...? However, Im not sure if it has the ATF sticker
                        G.Verelli
                        • 87e30
                          • Jul 2008
                          • 5676
                          #72
                          I much prefer the royal purple trans fluid in my car. I had redline but it didn't feel great. Granted I have a somewhat poor g260 (in my opinion) so it could just be my trans.
                          I just hate everyone.
                          No need for discretion.
                          • 8380 Labs
                            • Oct 2006
                            • 2990
                            #73
                            mine is also a bit notchy until it gets warmed up, but once it does it's nice and smooth.
                            8380 Laboratories
                            M3 Champs Poster
                            • Ian Bowers
                              • Apr 2008
                              • 1120
                              #74
                              Mine doesn't get smoother as it warms up, if anything, it gets a bit worse. :( It use to be super smooth with whatever was in it, and now it actually gives me hassles going into gears.
                              • gverelli
                                • Dec 2008
                                • 772
                                #75
                                ^^ I may change to OEM stuff and see how that feels because I am not happy with the MTL, it shifted perfectly before and it seems much notchier
                                G.Verelli
