Redline MTL... Yummy
  • Jean
    • 18228
    #46
    Ended up using Redline MTL in my g260/6 and it shifts like butter, I am not hearing a tranny noise etc...
    • ///M42 sport
      • 3952
      #47
      How are ya'll pump the oil in the tranny and diff?
      • MIKe30
        • Sep 2006
        • 2334
        #48
        ya'llllllll seem to do it this way...
        either buy a pump/turkey baster type thing and fill and purge into the tranny. Or run a hose behind the motor underneath the firewall into the tranny tunnel to the fill hole. Use a funnel at your end of the hose, fill till done. Gonna try method two later today...
          • 34844
          #49
          uh, they make pumps for this.. they cost like $15.
          • Andrew325is
            • Jan 2008
            • 1212
            #50
            I bought a transfer pump from Harbor Freight Tools for $5.99. Worked perfect!
            Plug and Play Wiring Harness Adapters for S54, S50, M54 and more.
            • SpecM
              • Oct 2005
              • 4531
              #51
              just get creative with a tube and a hose clamp, and squeeze the bottle, and the goo goes up the tube
              1989 cirrisblau-metallic 325i
              • Jean
                • 18228
                #52
                says off redlines website
                75W90 NS GL-5 Gear Oil
                * Designed for transmissions and transaxles - helps to slow synchros for easier shifting across a broad temperature range
                # Contains extreme pressure additives like our 75W90 GL-5 oil, but lacks friction modifiers to balance slipperiness
                # Improved copper corrosion protection to prolong synchro life
                # Helps with lock-up on weak limited-slip differentials-compatible with Red Line Limited Slip Friction Modifier for tuning slippage
                # Also used with clutch-type LSDs in racing for maximum lock up
                MTL 70W80 GL-4 Gear Oil
                * Popular in manual transmissions and transaxles like BMW (before 1993), Honda and Acura, Ford Focus, late-model Mini Cooper, Dodge & Jeep NV 1500, 3500, and 5600
                Is that of concern for our diffs? Royal Purple has the friction modifiers I believe.
                  • 34844
                  #53
                  you want their regular 75w90, NS stands for the version without friction modifiers
                  • Jean
                    • 18228
                    #54
                    Thanks! I'll pick up 2 qts.
                    • Edev
                      • 3731
                      #55
                      So for my old tranny, 75w90 (Redline) will be good? Or that 70w80, like Jean mentioned eariler.
                      M Coupe
                        • 34844
                        #56
                        75w90 for the diffs, 70w80 for the transmission, although you can put 75w90NS in the transmission too.
                        I'm using redline "shock proof" in my transfercase. that shit is fucking nasty.
                        • Jean
                          • 18228
                          #57
                          nando - picked up two bottles of regular redline 75w90 for the diff today per your suggestion :)
                          • wolfgangstbd
                            • 960
                            #58
                            i do this but flip te bottle poke a hole in the bottle and shove a air gun(whatever you wanna call it) regulated at like 20psi then just watch the goo go in seeconds :)
                            also does the g240 use same stuff?
                            • tonytony
                              Knee deep in poopie
                              • Jan 2004
                              • 3498
                              #59
                              joe's sports was going out of business so i stocked up on some royal purple 5w30 motor oil and some how ended up with two atf oil(bottles look the same). Anyway since i have the oil will it be ok to put ATF in my tranny? I have a 91 g260 if that makes any difference. The answer is probably yes, but I just wanted to make sure it's legit
                              • SamE30e
                                • Sep 2007
                                • 4319
                                #60
                                Amsoil MTL what up!?!?
                                1985 325e 2.8 Turbo VEMS
