Originally posted by Jordan
Drove my s52e30 for the first time
I do some work myself - like slamming it thru corners - does that count?Originally posted by JordanNah. My paint looks like shit. There are still numerious mistakes that need to be fixed and or repainted.Originally posted by brodeeHonest question for you Jordan... Do you have pride in your paintjob?Originally posted by JordanThats just fine and dandy.. but then you have no right to have pride in your machine, as its not your workmanship.
The body shop hates me.
As far as the spending time with wife and kids comments. Good for you, still... work on your own car. A S52 swap isnt something that should be handed off to a shop.
Seriously - any project that I can get done in a weekend with the tools I own I do. I will probably replace the rear bushings and such myself - I installed the exhaust myself - etc....Comment
I can See where Jordan is coming from this, but i can also see where others are coming from. Now, myself, if i had the money, i would Love to do a DOHC swap myself. But, knowing my current mechanical abilities, i'd rather not waste a good engine, putting it in incorrectly or half-assed, and messsing something up, leading to ruin-ing a good engine.
ok we get it, not everyone agrees with jordan.Originally posted by zxdNone of you have the right to have pride in your E30's because you didn't build it and it's not your workmanship.
*sarcasm of course*
i dont agree with what he said, but i know he has a point.
it doesnt have to be a jordan bashing thread, a few coments were plentyComment
Did you ever find out your displacement?
Id try and track down some S52 headers for that. Should make a good flow increase.
Im having a shop to the vast majority of the work because I dont have anything but simple hand tools. Not to mention this isnt just a mechanic but a race prep/support shop.Im now E30less.
sigpicComment
Agreed. I found a set through turner and put them on my S50.
gae30, it's nice to see you have your priorities in order... For myself, it has been a great project and I've had a ton of fun doing it. I'm probably about a week away from firing it up and I cant wait. I've been working on the car since last october, a little here and a little there when time allows...
Originally posted by Simon SWhen a dream is a dream for too long - it becomes a fantasy..
On the S50 above (in the white E30), what happened to your oil filter housing? Looks like you blanked it out with a custom plate.
Is the red tube on the pass. side of the engine compartment the new oil filter?
Just curious if this is the case and why?
Nice looking swap.Comment
Yup, it does and you will definatley want to run one. I've got one on my car and Blunt is running one on his car as well. The 5 series pan hangs really low, the skidplate is good insurance.Originally posted by Ryan Stewarthmmm, i wonder if the E30 skidplate clears?
I am running the VAC 24v oil block(deletes the stock canister) with sender ports, a 25 row Mocal oil cooler, and Peterson oil filter( the red thingy). It's a serviceable filter that you clean with brake-kleen and re-use. The car will get tracked quite a bit so this should save some money on filters in the long run. I figure I will also be able to squeeze in another 1-2 quarts with all of the extra plumbing.Originally posted by Simon SWhen a dream is a dream for too long - it becomes a fantasy..
When your ego is out of check (insert your own comments here).Originally posted by gae30But do you always have to be such a jackass?Don't forget the good things Hitler did.Comment
