preventative maintenance
  • Mountain30
    • Jun 2020
    • 2
    Hi Everyone,
    New member and new e30 owner here. Looked for the right car for 6 months and just purchased one here locally in Denver. Un-modified 1987 (June) 325is with 144k miles. Starts, idles, runs, shifts, handles and breaks great. Such a pleasure to drive. As I only have the sellers word that the timing belt has been replaced, I'm going to go ahead with the following preventative maintenance:
    Pull radiator and have it flushed and flow tested - replace if necessary
    New timing belt
    New water pump
    New themostat
    New cam seal and flange o-ring
    New BMW blue coolant
    Check all hoses and replace if necessary
    Ireland Engineering has a kit with all these parts and they seem like a good parts company.
    Are there any other critical preventative maintenance issues that I should deal with right away? Fan clutch? Coolant sensors (temp gauge works and fan turns on as it should)? Any advice or link to a previous thread on this topic would be greatly appreciated.
    Thanks!
  • cheffy30
    • Sep 2016
    • 1159
    check all hoses are fresh. all under carriage bushings and boots post some pics sent from hell using tapatalk
    '90 325i sedan daily driven
    '85 325e coupe also a daily
    • MrBurgundy
      R3V Degenerate
      • Mar 2012
      • 5597
      If we're just talking about the engine there's not too many failure points outside what you've said you're going to do.
      There's only a few sensors that are critical to how the engine runs.
      Blue coolant temp, throttle position switch and the CPS. Your temp gauge has a one pin brown sesnor that is independent of the one that talks to the ECU. That one is blue, located next to the brown one.
      Also, the connector under the intake, also known as the C191 is usually the culprit for some odd thing that happen. You can undo it by rotating it and check to see if there is any corrosion in there and if there is, just get something to dissolve it.
      You can also take off the idle control valve and run some carb cleaner through it to insure that the vane is moving freely
      Check the rubber things on it like; intake boot, breather hose from the throttle to the valve cover, make sure the fittings for both vacuum hoses on the throttle aren't rotating (which means they can leak) and of course the back side of the intake to the fuel pressure regulator.
      Also, make sure the valve adjustment is correct. Some people just never have them done. I usually do it 1 a year, but I find that they're usually within spec even with that time, which equates to about 5k miles.
      Fan clutch would provide a piece of mind, but you can do a simple test and see how it's current condition.
      Pretty simple engines.
      • Mountain30
        • Jun 2020
        • 2
        Thanks MrBurgundy and cheffy30. I went ahead and ordered a new hose set and fan clutch just to be on the safe side. Thanks for the advice.
        • Vincenze
          • Apr 2019
          • 1034
          You'll need a thin 32mm wrench and a holder to unscrew the fan clutch.
          Examine parts websites:
          https://www.pelicanparts.com/BMW/index-SC.htm
          https://www.ecstuning.com/
          https://www.fcpeuro.com/
          And compare them to https://www.realoem.com/bmw/enUS/select
          Those websites show parts that may be needed for each job.
          These How-Tos are useful for the type of job that you want to do: https://classicbimmerbits.com/e30-how-to/
          and youtube videos, of course.
          • e30austin
            • 15382
            here's what i do, as a baseline, for just about every e30 that comes through my shop... (in other words, if it's been sitting for a while or is otherwise neglected)
            timing belt/water pump/cam seal
            coolant flush
            drive belts
            oil service
            fan clutch
            cap/rotor/plugs
            valve cover gasket + valve adjustment
            air mass meter boot + valve cover breather hose
            all fuel hoses + fuel filter (this is one that 99% of people overlook, most e30s still have their original fuel hoses and original fuel filter, EEK)
            blue coolant temp switch
            i also like to change all the cooling hoses (yes, every single one) - thermostat/overflow hose, upper/lower rad hoses, water pump hose, water pipe hose, throttle body heater hoses, cyl head/heater core hose, and reseal the throttle body heater (they always leak).
            congrats on your new e30. i hope it's everything you thought it would be. '87 325is is the coolest e30, imho.
            • varg
              Florida Turbo Man
              • May 2014
              • 3423
              Or a suitably slim adjustable nut rounder and a mallet
              IG @turbovarg
              '91 318is, M20 turbo
              • Aleman
                • Mar 2012
                • 1607
                This one from Park works perfectly:
                https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                R135 /// 1990 Alpinweiß II 325is
                └┼┼┘ /// 1993 Black/Black Convertible (sold)
                ..24
                • Vincenze
                  • Apr 2019
                  • 1034
                  You may just buy a kit.
                  The pulley holder is very useful.
                  • uturn
                    • Dec 2010
                    • 1005
                    Everyone else probably uses an excel spreadsheet, I still use a small notebook. I track the date, estimated cost of parts and mileage when work or maintenance was done. Helps me keep track of oil changes.
                    • cheffy30
                      • Sep 2016
                      • 1159
                      I have a 3 ring with every maintenance record in chronological order dating back 20 years I have had her including the bill of sale. it's fun to look back. she just moved into 297k over the weekend. I change the oil every 3k sent from hell using tapatalk
                      • TooTall90
                        • 338
                        Im kinda in the same boat, shopping around for timing belt kits. does anyone have a preference or "things to look for" when it comes to those?
                        Strategic Alpine Command:...sig loading
                        • cheffy30
                          • Sep 2016
                          • 1159
                          there's a few. I've been using Continental over the years. sent from hell using tapatalk
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            You pretty much have Continental & Gates who probably get their tensioners from Febi, FAG/SKF, or INA. All of those are fine, with maybe the only one to use as a secondary choice being Febi.
                            • TooTall90
                              • 338
                              yeah thats what i figured. however i didnt know Febi was second rate, i just got a coolant sensor from them. i feel like febi was respectable back in 2010 when i had my old e30, maybe i was wrong, im not stressing it though.
